简介
Put this guide to work in order to replace your leaking seal in the blade assembly, Note the seal is located inside of the existing blade assembly.
你所需要的
Grip the blender base with one hand and blender bottle with the other hand.
Rotate the blender bottle a quarter turn counterclockwise .
Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
After separating the blade assembly from the blender bottle, position the plastic opening tool on either side of the seal in the blade assembly.
Wedge tool between seal and seal seat wall.
3等其他人完成本指南。
