跳转到主内容
Oster Blend-N-Go My Blend Blade Assembly Replacement
  1. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: 步骤 1 中的图像 1,2 Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: 步骤 1 中的图像 2,2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blade Assembly Replacement: 步骤 2 中的图像 1,3 Oster Blend-N-Go My Blend Blade Assembly Replacement: 步骤 2 中的图像 2,3 Oster Blend-N-Go My Blend Blade Assembly Replacement: 步骤 2 中的图像 3,3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blade Assembly: 步骤 3 中的图像 1,1
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
结论
另外一个人完成了本指南。
Paul Long
于08/27/15注册
710 声望
创作了4篇指南
团队
USF Tampa, Team 12-6, Blackwell Fall 2015 USF Tampa, Team 12-6, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G6
3 名成员
创作了5篇指南
2条评论
I’m confused, these are the steps you have to go through every single time you use this blender to blend something. This isn’t really a “replacement” process here. If someone needs to repair a cracked blade assembly or buy a new one, how would they do that?
Alan M - 回复
This process is not helpful at all. I followed as instructed but the blade is not moving at all?! What is going on? Pls provide better HELP INSTRUCTIONS.
Fareda Edwards - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 3,575
