跳转到主内容
简介
Use this guide to replace your damaged Blade Assembly.
  1. Grip the blender base with one hand and blender bottle with the other hand. Rotate the blender bottle a quarter turn counterclockwise .
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Grip the blade assembly with one hand and blender bottle with the other hand. Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle. Lift the blender bottle to separate it from the blade assembly.
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
结论
另外一个人完成了本指南。
Paul Long
于2015年08月27日注册
698 信誉积分
创作了4篇指南
团队
USF Tampa, Team 12-6, Blackwell Fall 2015 USF Tampa, Team 12-6, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G6
3 名成员
创作了5篇指南
I’m confused, these are the steps you have to go through every single time you use this blender to blend something. This isn’t really a “replacement” process here. If someone needs to repair a cracked blade assembly or buy a new one, how would they do that?
Alan M - 回复
This process is not helpful at all. I followed as instructed but the blade is not moving at all?! What is going on? Pls provide better HELP INSTRUCTIONS.
Fareda Edwards - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 28
总计 2,789
