跳转到主内容
Oster BLSTSS-PZO Blades & Seal Ring Replacement
  1. Oster BLSTSS-PZO Blades & Seal Ring Replacement, Blades & Seal Ring: 步骤 1 中的图像 1,1
    • First, remove the blender container from the blender base by grabbing the container and lifting it up.
  2. Oster BLSTSS-PZO Blades & Seal Ring Replacement: 步骤 2 中的图像 1,1
    • Flip the container, where the bottom faces you.
    • Then, rotate the bottom piece counter-clockwise to remove it from the container.
  3. Oster BLSTSS-PZO Blades & Seal Ring Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the bottom piece from the container.
    • Be careful while removing the blades from the container, as seeing they are very sharp and can hurt you.
  4. Oster BLSTSS-PZO Blades & Seal Ring Replacement: 步骤 4 中的图像 1,1
    • Now, your container and blades are separated.
结论
Farhan
于09/20/17注册
104 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 489
