跳转到主内容
Oster 6329 Lever Catch Spring Replacement
你所需要的
  1. Oster 6329 Lever Catch Spring Replacement, Outer Shell Removal: 步骤 1 中的图像 1,2 Oster 6329 Lever Catch Spring Replacement, Outer Shell Removal: 步骤 1 中的图像 2,2
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Lever Catch Spring Replacement: 步骤 2 中的图像 1,1
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Lever Catch Spring Replacement: 步骤 3 中的图像 1,1
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Lever Catch Spring Replacement: 步骤 4 中的图像 1,2 Oster 6329 Lever Catch Spring Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Lever Catch Spring Replacement: 步骤 5 中的图像 1,2 Oster 6329 Lever Catch Spring Replacement: 步骤 5 中的图像 2,2
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
  6. Oster 6329 Lever Catch Spring Replacement, Lever Catch Spring: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Insert the tweezers between the spring and the bottom of the lever to release the spring.
  7. Oster 6329 Lever Catch Spring Replacement: 步骤 7 中的图像 1,2 Oster 6329 Lever Catch Spring Replacement: 步骤 7 中的图像 2,2
    • Remove spring from the bottom of the lever.
    • The spring should only be connected to the top of the toaster after this is complete.
  8. Oster 6329 Lever Catch Spring Replacement: 步骤 8 中的图像 1,1
    • Insert the tweezers between the two metal flaps located at the top of the toaster.
    • Hold the spring and turn it sideways to lay it flat along the top of the toaster.
    • Pry the spring from the top of the toaster.
结论
Blaine Oelkers
于01/24/14注册
116 声望
撰写一个指南
团队
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G15
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,075
