简介
This repair is challenging because the wire that acts as the spring is difficult to bend into the correct shape.
你所需要的
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Press down on the toaster handle to access to the grabber spring located behind the large metal plate.
2等其他人完成本指南。
