跳转到主内容
Oster 3905 Outer Shell Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Oster 3905 Outer Shell Replacement, Slot Levers: 步骤 1 中的图像 1,1
    • Firmly grip your hand around the slot lever.
  2. Oster 3905 Outer Shell Replacement: 步骤 2 中的图像 1,1
    • Stabilize the toaster by placing your hand on top.
  3. Oster 3905 Outer Shell Replacement: 步骤 3 中的图像 1,2 Oster 3905 Outer Shell Replacement: 步骤 3 中的图像 2,2
    • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
  4. Oster 3905 Outer Shell Replacement: 步骤 4 中的图像 1,1
    • Both slot levers can be removed.
  5. Oster 3905 Outer Shell Replacement, Outer Shell: 步骤 5 中的图像 1,1
    • Place the toaster upside down so the bottom is facing the ceiling.
  6. Oster 3905 Outer Shell Replacement: 步骤 6 中的图像 1,2 Oster 3905 Outer Shell Replacement: 步骤 6 中的图像 2,2
    • Take off both rubber feet using a small metal spudger.
    • Wedge a spudger under the feet and pull up to pop off.
  7. Oster 3905 Outer Shell Replacement: 步骤 7 中的图像 1,1
    • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
    • There are two screws under the rubber feet.
  8. Oster 3905 Outer Shell Replacement: 步骤 8 中的图像 1,1
    • Place the toaster right side up.
  9. Oster 3905 Outer Shell Replacement: 步骤 9 中的图像 1,2 Oster 3905 Outer Shell Replacement: 步骤 9 中的图像 2,2
    • Grab the outer shell firmly and pull up towards the face of the toaster.
  10. Oster 3905 Outer Shell Replacement: 步骤 10 中的图像 1,1
    • For this part, you might need to wiggle the toaster to get the outer shell off.
    • The shell will not completely come off until the motherboard is removed in the next step.
  11. Oster 3905 Outer Shell Replacement: 步骤 11 中的图像 1,3 Oster 3905 Outer Shell Replacement: 步骤 11 中的图像 2,3 Oster 3905 Outer Shell Replacement: 步骤 11 中的图像 3,3
    • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
  12. Oster 3905 Outer Shell Replacement: 步骤 12 中的图像 1,2 Oster 3905 Outer Shell Replacement: 步骤 12 中的图像 2,2
    • Take out the grey “cancel” and “bagel” buttons from the shell.
结论
Melissa
于09/12/16注册
198 声望
撰写一个指南
团队
CSU Fullerton, Team 2-1, Bruce Fall 2016 CSU Fullerton, Team 2-1, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S2G1
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 122
