跳转到主内容
Oster 3905 Heat Coil Replacement
你所需要的
  1. Oster 3905 Heat Coil Replacement, Slot Levers: 步骤 1 中的图像 1,1
    • Firmly grip your hand around the slot lever.
  2. Oster 3905 Heat Coil Replacement: 步骤 2 中的图像 1,1
    • Stabilize the toaster by placing your hand on top.
  3. Oster 3905 Heat Coil Replacement: 步骤 3 中的图像 1,2 Oster 3905 Heat Coil Replacement: 步骤 3 中的图像 2,2
    • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
  4. Oster 3905 Heat Coil Replacement: 步骤 4 中的图像 1,1
    • Both slot levers can be removed.
  5. Oster 3905 Heat Coil Replacement, Outer Shell: 步骤 5 中的图像 1,1
    • Place the toaster upside down so the bottom is facing the ceiling.
  6. Oster 3905 Heat Coil Replacement: 步骤 6 中的图像 1,2 Oster 3905 Heat Coil Replacement: 步骤 6 中的图像 2,2
    • Take off both rubber feet using a small metal spudger.
    • Wedge a spudger under the feet and pull up to pop off.
  7. Oster 3905 Heat Coil Replacement: 步骤 7 中的图像 1,1
    • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
    • There are two screws under the rubber feet.
  8. Oster 3905 Heat Coil Replacement: 步骤 8 中的图像 1,1
    • Place the toaster right side up.
  9. Oster 3905 Heat Coil Replacement: 步骤 9 中的图像 1,2 Oster 3905 Heat Coil Replacement: 步骤 9 中的图像 2,2
    • Grab the outer shell firmly and pull up towards the face of the toaster.
  10. Oster 3905 Heat Coil Replacement: 步骤 10 中的图像 1,1
    • For this part, you might need to wiggle the toaster to get the outer shell off.
    • The shell will not completely come off until the motherboard is removed in the next step.
  11. Oster 3905 Heat Coil Replacement: 步骤 11 中的图像 1,3 Oster 3905 Heat Coil Replacement: 步骤 11 中的图像 2,3 Oster 3905 Heat Coil Replacement: 步骤 11 中的图像 3,3
    • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
  12. Oster 3905 Heat Coil Replacement: 步骤 12 中的图像 1,2 Oster 3905 Heat Coil Replacement: 步骤 12 中的图像 2,2
    • Take out the grey “cancel” and “bagel” buttons from the shell.
  13. Oster 3905 Heat Coil Replacement, Heat Coil: 步骤 13 中的图像 1,1
    • Once the outer shell is removed, rotate toaster so the back is facing you.
  14. Oster 3905 Heat Coil Replacement: 步骤 14 中的图像 1,2 Oster 3905 Heat Coil Replacement: 步骤 14 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use flat head tweezers and plastic opening tool to remove the top metal panel by prying the metal tabs upwards so they are able to slide through the openings and pull upwards.
    • There is a total of 8 tabs, 4 on each side.
  15. Oster 3905 Heat Coil Replacement: 步骤 15 中的图像 1,3 Oster 3905 Heat Coil Replacement: 步骤 15 中的图像 2,3 Oster 3905 Heat Coil Replacement: 步骤 15 中的图像 3,3
    • Once top metal panel is unhooked. Lift and let hang off the side of the toaster.
  16. Oster 3905 Heat Coil Replacement: 步骤 16 中的图像 1,2 Oster 3905 Heat Coil Replacement: 步骤 16 中的图像 2,2
    • Turn the toaster so that the faulty wire side is facing you.
    • Position the top 5 metal tabs to fit through slots .
  17. Oster 3905 Heat Coil Replacement: 步骤 17 中的图像 1,1
    • Position the 4 side tabs to fit thought the slots.
  18. Oster 3905 Heat Coil Replacement: 步骤 18 中的图像 1,2 Oster 3905 Heat Coil Replacement: 步骤 18 中的图像 2,2
    • Pull the metal sheet away from the toaster to expose the heating board.
  19. Oster 3905 Heat Coil Replacement: 步骤 19 中的图像 1,2 Oster 3905 Heat Coil Replacement: 步骤 19 中的图像 2,2
    • Position the 4 metals tabs on the heating board. Found at the top right and bottom left.
  20. Oster 3905 Heat Coil Replacement: 步骤 20 中的图像 1,2 Oster 3905 Heat Coil Replacement: 步骤 20 中的图像 2,2
    • At the bottom of the heating board, there are 2 tabs holding it to the rest of the toaster, pull those 2 tabs upwards to release heating board from the toaster.
  21. Oster 3905 Heat Coil Replacement: 步骤 21 中的图像 1,2 Oster 3905 Heat Coil Replacement: 步骤 21 中的图像 2,2
    • There should now be 2 wires connected to the heating board that would need to be de-soldered to disconnect.
    • You can replace the wires on the heating board or if your wires are damaged or disconnect, solder together to fix
结论
Alexus Reyes
于09/12/16注册
233 声望
撰写一个指南
团队
CSU Fullerton, Team 2-1, Bruce Fall 2016 CSU Fullerton, Team 2-1, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S2G1
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 501
