简介
Use this guide to remove the blades from the blender in order to replace them.
First, remove the blender container from the Blender Base, by grabbing the handle and lifting up.
Now you will see the bottom of the blender blades once the bottom piece is removed
Does it pop off or need to unscrewed?
I had to get a new glass container and have the base off but can’t figure out how to get the blades out!
Flip the blender container on its side so that the bottom faces you.
Now, you can insert the new set of blades into the container.
即将完成!
结论
