跳转到主内容
Osram Lightify Disassembly
你所需要的
  1. Osram Lightify Disassembly, Osram: 步骤 1 中的图像 1,1
    • Remove the front using a metal spudger.
    • Once you can get your fingers in, remove the rest using your hand.
  2. Osram Lightify Disassembly: 步骤 2 中的图像 1,2 Osram Lightify Disassembly: 步骤 2 中的图像 2,2
    • On the back of the front cover, remove the white plastic using a metal spudger.
    • Remove the PCB using a spudger
  3. Osram Lightify Disassembly: 步骤 3 中的图像 1,2 Osram Lightify Disassembly: 步骤 3 中的图像 2,2
    • Once the PCB is removed, use a Torx T9 screwdriver to unscrew and remove the power supply.
    • Remove the screws holding on the back cover with a Torx T9 screwdriver and remove the back cover.
    • all the screws are the same. they can be mixed with no problem.
  4. Osram Lightify Disassembly: 步骤 4 中的图像 1,3 Osram Lightify Disassembly: 步骤 4 中的图像 2,3 Osram Lightify Disassembly: 步骤 4 中的图像 3,3
    • Remove the button by grabbing the tab over the button and pulling it out.
    • it will not come out if the button is not depressed.
    • Remove both metal sheets. when its at an angle, push it in a little and then pull it up so that it is pointing straight up. then, you can push it through.
结论
另外一个人完成了本指南。
Aiden
于09/19/15注册
18,228 声望
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 360
