本指南有最近更改,您可查看未经巡查的最新版本。
简介
When trying to use my sprayer this year it would not hold any pressure. I unscrewed the main pump housing an saw that the main washer was cracked and falling apart. When I searched for a replacement gasket all I could find were kits that cost half as much as the sprayer.
你所需要的
Remove the main sprayer pump and take the gasket off. It is at the top of the threads. Try to save as much as you can to get the diameter.
Go to the plumbing section and locate the washers. I found this particular washer in the toilet and bath tub section. The inner diameter can be a little smaller but it should have a similar width.
For $2 you can have your sprayer going again.
另外一个人完成了本指南。
