跳转到主内容
Ortho Yard & Garden Sprayer Main Gasket Replacement
你所需要的
    • Remove the main sprayer pump and take the gasket off. It is at the top of the threads. Try to save as much as you can to get the diameter.
  1. Ortho Yard & Garden Sprayer Main Gasket Replacement, Take the gasket to the hardware store: 步骤 2 中的图像 1,1
    • Go to the plumbing section and locate the washers. I found this particular washer in the toilet and bath tub section. The inner diameter can be a little smaller but it should have a similar width.
    • Replace the gasket.
结论
For $2 you can have your sprayer going again.
另外一个人完成了本指南。
Joe Bailey
于04/10/16注册
182 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 2,269
