跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Xbox Controller,应参考我们的维修指南
  1. Original XBox Controller Teardown, Taking Off the Back Cover: 步骤 1 中的图像 1,1
    • The first thing you want to do is to turn over the XBox controller and locate the 4 screws on the back. Next you want to unscrew the screws and set them together off to the side.
  2. Original XBox Controller Teardown, What You Will See Inside: 步骤 2 中的图像 1,1
    • You will be looking at the controllers circuit board. There will be another screw in the middle of the board that you would want to take out as well. It's a different type of screw from the ones on the back cover, so separate that screw and the ones from the back cover.
  3. Original XBox Controller Teardown, What's in the Back: 步骤 3 中的图像 1,1
    • In the back, you will see the vibrator motors (Red) in the controller handles. You will also see the shoulder buttons (Blue) and the controllers central "Hub" where all the power is stored (Orange).
  4. Original XBox Controller Teardown, Reconstructing the Controller: 步骤 4 中的图像 1,2 Original XBox Controller Teardown, Reconstructing the Controller: 步骤 4 中的图像 2,2
    • After you are done looking around inside the XBox controller, you can start to put it back together.
    • Put the screw back in that you took out from the circuit board, and put back any buttons or anything else that you took out.
    • Then you want to put the back cover back on the controller and put the 4 screws back in.
    • And now your done!
R0B8I3 O
于04/19/18注册
168 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 69
总计 4,177
