跳转到主内容
Oreva FX-82MS Battery Replacement
你所需要的
  1. Oreva FX-82MS Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the calculator by pressing the [Shift] button and then press the [AC][OFF] button, (while keeping the [Shift] button pressed down).
  2. Oreva FX-82MS Battery Replacement: 步骤 2 中的图像 1,2 Oreva FX-82MS Battery Replacement: 步骤 2 中的图像 2,2
    • Flip the calculator over so that the back panel faces up.
    • Use a Phillips #0 screwdriver to remove six, 1.2 mm screws starting from the upper right corner.
  3. Oreva FX-82MS Battery Replacement: 步骤 3 中的图像 1,2 Oreva FX-82MS Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the back cover and put it to the side.
  4. Oreva FX-82MS Battery Replacement: 步骤 4 中的图像 1,2 Oreva FX-82MS Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the two old batteries from the slots.
    • Be gentle when removing the batteries to avoid damaging the connectors.
  5. Oreva FX-82MS Battery Replacement: 步骤 5 中的图像 1,3 Oreva FX-82MS Battery Replacement: 步骤 5 中的图像 2,3 Oreva FX-82MS Battery Replacement: 步骤 5 中的图像 3,3
    • Place the two new AAA batteries into the calculator, one by one.
    • Be sure that the direction of the + and - signs on your battery match the signs at the bottom of the battery compartment.
    • Place the case on back of the calculator.
  6. Oreva FX-82MS Battery Replacement: 步骤 6 中的图像 1,2 Oreva FX-82MS Battery Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips #0 screwdriver to replace the 1.2 mm screws on the back case.
  7. Oreva FX-82MS Battery Replacement: 步骤 7 中的图像 1,1
    • Reset the calculator by pressing [ON].
    • Press the [shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3][ALL] button option.
    • Press [=] [yes] button to agree.
    • Press [AC] key to reset.
结论
2等其他人完成本指南。
Prarthit patel
于07/02/22注册
196 声望
撰写一个指南
团队
York University, Team M-22, Allen Summer 2022 York University, Team M-22, Allen Summer 2022 的会员
YORK-ALLEN-SU22SMG22
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 86
总计 2,038
