跳转到主内容
加入维修社区 - 创建账户
Oregon Scientific RM318PA Lens Replacement
你所需要的
    1. Oregon Scientific RM318PA Lens Replacement, A/C Adapter: 步骤 1 中的图像 1,3 Oregon Scientific RM318PA Lens Replacement, A/C Adapter: 步骤 1 中的图像 2,3 Oregon Scientific RM318PA Lens Replacement, A/C Adapter: 步骤 1 中的图像 3,3
      • Hold clock so the screen is facing away from you.
      • Using your thumbs, push up on battery cover to remove.
      • With your other hand, pull down on the A/C Adapter jack to remove.
      询问修复机器人
      添加评论
    2. Oregon Scientific RM318PA Lens Replacement, Batteries: 步骤 2 中的图像 1,1
      • Remove batteries by pushing a battery toward the spring.
      • Lift battery out at an angle. Repeat with second battery.
      询问修复机器人
      添加评论
    3. Oregon Scientific RM318PA Lens Replacement, Projection Arm: 步骤 3 中的图像 1,2 Oregon Scientific RM318PA Lens Replacement, Projection Arm: 步骤 3 中的图像 2,2
      • Use a Phillips #00 Screwdriver to remove the four (4) screws from the back of the projection arm.
      • Once screws are removed, lift the back up and off of the projection arm.
      询问修复机器人
      添加评论
    4. Oregon Scientific RM318PA Lens Replacement, Screws Projection Arm: 步骤 4 中的图像 1,2 Oregon Scientific RM318PA Lens Replacement, Screws Projection Arm: 步骤 4 中的图像 2,2
      • Use a Phillips #00 Screwdriver to remove two (2) screws from back of projection arm.
      询问修复机器人
      添加评论
    5. Oregon Scientific RM318PA Lens Replacement, Front of the Projection Arm: 步骤 5 中的图像 1,2 Oregon Scientific RM318PA Lens Replacement, Front of the Projection Arm: 步骤 5 中的图像 2,2
      • Use a Plastic Opening Tool to pry open the front of the projection arm casing. Start at the top of the projection arm.
      • Once top is partially open, use a Spudger to pry at the side of the projection arm.
      询问修复机器人
      添加评论
    6. Oregon Scientific RM318PA Lens Replacement, Projection Beam: 步骤 6 中的图像 1,3 Oregon Scientific RM318PA Lens Replacement, Projection Beam: 步骤 6 中的图像 2,3 Oregon Scientific RM318PA Lens Replacement, Projection Beam: 步骤 6 中的图像 3,3
      • Turn the clock on its side. Slide the focus wheel forward with your thumb.
      • The Projection Beam and Focus Wheel Component should now be free of Projection Arm.
      • Hold the Component in one hand and lift the Projection Beam up and away from the Focus Wheel.
      询问修复机器人
      添加评论
    7. Oregon Scientific RM318PA Lens Replacement, The Lens: 步骤 7 中的图像 1,1
      • The Lens is attached to the Focus Knob and is now accessible for replacement purposes.
      询问修复机器人
      添加评论
    8. Oregon Scientific RM318PA Lens Replacement, Tape: 步骤 8 中的图像 1,1
      • Apply tape to the lens for safe removal and prevention of injury.
      询问修复机器人
      添加评论
    9. Oregon Scientific RM318PA Lens Replacement, Focus Knob: 步骤 9 中的图像 1,2 Oregon Scientific RM318PA Lens Replacement, Focus Knob: 步骤 9 中的图像 2,2
      • Detach the focus knob from the internal casing of the lens by removing the screw from the base of the focus knob grip.
      • Pry apart the pieces of casing holding the focus knob in place and remove the knob.
      询问修复机器人
      添加评论
    10. Oregon Scientific RM318PA Lens Replacement, Internal Casing: 步骤 10 中的图像 1,3 Oregon Scientific RM318PA Lens Replacement, Internal Casing: 步骤 10 中的图像 2,3 Oregon Scientific RM318PA Lens Replacement, Internal Casing: 步骤 10 中的图像 3,3
      • Insert the spudger into the opening above the hinge on the side of the casing.
      • Press down firmly until the case opens.
      询问修复机器人
      添加评论
    11. Oregon Scientific RM318PA Lens Replacement, Lens Removal: 步骤 11 中的图像 1,2 Oregon Scientific RM318PA Lens Replacement, Lens Removal: 步骤 11 中的图像 2,2
      • Pull apart the casing and gently slide lens from pocket.
      • Be sure to replace with a concave lens.
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
1指南评论
Hi, I’ve this alarm clock with missing piezo/speaker, can anyone take a picture of the main board showing the pads for it?
Mastto geppetto - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 27
过去 30 天: 61
总计 3,240
