跳转到主内容
Oregon Scientific RM318PA Focus Knob Replacement
你所需要的
  1. Oregon Scientific RM318PA Focus Knob Replacement, A/C Adapter: 步骤 1 中的图像 1,3 Oregon Scientific RM318PA Focus Knob Replacement, A/C Adapter: 步骤 1 中的图像 2,3 Oregon Scientific RM318PA Focus Knob Replacement, A/C Adapter: 步骤 1 中的图像 3,3
    • Hold Clock so the screen is facing away from you.
    • Using your thumbs, push up on battery cover to remove.
    • With your other hand, pull down on the A/C Adapter jack to remove.
  2. Oregon Scientific RM318PA Focus Knob Replacement, Batteries: 步骤 2 中的图像 1,1
    • Remove batteries by pushing a battery toward the spring.
    • Lift battery out at an angle. Repeat with second battery.
  3. Oregon Scientific RM318PA Focus Knob Replacement, Projection Arm: 步骤 3 中的图像 1,3 Oregon Scientific RM318PA Focus Knob Replacement, Projection Arm: 步骤 3 中的图像 2,3 Oregon Scientific RM318PA Focus Knob Replacement, Projection Arm: 步骤 3 中的图像 3,3
    • Use a Phillips #00 Screwdriver to remove the four (4) screws from the back of the projection arm.
    • Once screws are removed, lift the back up and off of the projection arm.
  4. Oregon Scientific RM318PA Focus Knob Replacement: 步骤 4 中的图像 1,2 Oregon Scientific RM318PA Focus Knob Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #00 Screwdriver to remove two (2) screws from back of projection arm.
  5. Oregon Scientific RM318PA Focus Knob Replacement: 步骤 5 中的图像 1,2 Oregon Scientific RM318PA Focus Knob Replacement: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to pry apart the front of the projection arm casing. Start at the top of the projection arm.
    • Once top is partially open, use a spudger to pry at the side of the projection arm.
  6. Oregon Scientific RM318PA Focus Knob Replacement, Focus Knob: 步骤 6 中的图像 1,3 Oregon Scientific RM318PA Focus Knob Replacement, Focus Knob: 步骤 6 中的图像 2,3 Oregon Scientific RM318PA Focus Knob Replacement, Focus Knob: 步骤 6 中的图像 3,3
    • Turn the clock on its side. Slide the Focus Knob forward with your thumb.
    • The Focus Knob Component should now be free of Projection Arm.
    • Hold the Component in one hand and lift the Projection Beam up and away from the Focus Knob.
  7. Oregon Scientific RM318PA Focus Knob Replacement: 步骤 7 中的图像 1,3 Oregon Scientific RM318PA Focus Knob Replacement: 步骤 7 中的图像 2,3 Oregon Scientific RM318PA Focus Knob Replacement: 步骤 7 中的图像 3,3
    • Loosen Focus Knob by turning the Focus Knob counterclockwise with your fingers.
    • If needed, add a SMALL amount of WD-40 to the base of the knob and continue turning Focus Knob.
    • Place replacement Focus Knob in socket and turn clockwise to secure.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 873
