跳转到主内容
Oregon Scientific RM318PA A/C Power Adapter Replacement
  1. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter: 步骤 1 中的图像 1,2 Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter: 步骤 1 中的图像 2,2
    • To access the A/C Power Adapter connection, remove the battery cover, located on the back of the clock.
  2. Oregon Scientific RM318PA A/C Power Adapter Replacement, Battery Compartment Cover: 步骤 2 中的图像 1,2 Oregon Scientific RM318PA A/C Power Adapter Replacement, Battery Compartment Cover: 步骤 2 中的图像 2,2
    • To remove the battery compartment cover, slide the cover up towards the top of the clock while applying slight pressure.
  3. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter Socket: 步骤 3 中的图像 1,1
    • Gently pull the A/C Power Adapter from the socket, to the left of the batteries.
  4. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter Tip: 步骤 4 中的图像 1,1
    • To plug in the A/C Power Adapter, insert the tip into the socket, located to the left of the batteries, and press firmly.
    • Be sure that you are inserting an A/C Power Adapter and not a D/C Power Adapter. Inserting the improper cord could cause damage to the device.
  5. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter Cord: 步骤 5 中的图像 1,1
    • Once the A/C Power Adapter tip is inserted in the socket, guide the cord through a notch directly below.
结论
另外一个人完成了本指南。
4条评论
i need operating manual for model no.rm318pa.please send to…gjgeoff1@outlook.fr
jean-guy geoffroy - 回复
i need operating manuel
jean-guy geoffroy -
When you say make sure to insert AC power adapter what do you mean. It clearly says DC3V on the clock. Could you post the picture of the adapter without cord over the label?
Alex Olekh - 回复
Alex! Yes, right you are! DC not AC and Oregon Scientific will not answer my email requests. I am !#^&@@!
Ty Ford - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 23
总计 3,423
