跳转到主内容
加入维修社区 - 创建账户
Oregon Scientific Meep! X2 Screen Replacement
你所需要的
  1. Oregon Scientific Meep! X2 Screen Replacement, Rear Casing: 步骤 1 中的图像 1,1
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. Oregon Scientific Meep! X2 Screen Replacement: 步骤 2 中的图像 1,3 Oregon Scientific Meep! X2 Screen Replacement: 步骤 2 中的图像 2,3 Oregon Scientific Meep! X2 Screen Replacement: 步骤 2 中的图像 3,3
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Oregon Scientific Meep! X2 Screen Replacement: 步骤 3 中的图像 1,3 Oregon Scientific Meep! X2 Screen Replacement: 步骤 3 中的图像 2,3 Oregon Scientific Meep! X2 Screen Replacement: 步骤 3 中的图像 3,3
    • Use the plastic opening tools to undo the clips around the edges of the device.
  4. Oregon Scientific Meep! X2 Screen Replacement, Power Button: 步骤 4 中的图像 1,2 Oregon Scientific Meep! X2 Screen Replacement, Power Button: 步骤 4 中的图像 2,2
    • Use a tweezer to gently pull the power button sensor out of the case's slot.
  5. Oregon Scientific Meep! X2 Screen Replacement: 步骤 5 中的图像 1,2 Oregon Scientific Meep! X2 Screen Replacement: 步骤 5 中的图像 2,2
    • Use the soldering station to unsolder and remove the power button from the motherboard.
    • In the case of screen or screen sensor replacement, disregard desoldering steps.
  6. Oregon Scientific Meep! X2 Screen Replacement, Microphone: 步骤 6 中的图像 1,2 Oregon Scientific Meep! X2 Screen Replacement, Microphone: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Use your tweezers to gently remove the microphone from the slot in the casing.
  7. Oregon Scientific Meep! X2 Screen Replacement: 步骤 7 中的图像 1,2 Oregon Scientific Meep! X2 Screen Replacement: 步骤 7 中的图像 2,2
    • Unsolder the microphone unit from the motherboard using the soldering station.
  8. Oregon Scientific Meep! X2 Screen Replacement, Cameras: 步骤 8 中的图像 1,2 Oregon Scientific Meep! X2 Screen Replacement, Cameras: 步骤 8 中的图像 2,2
    • Slip the plastic opening tool under the white, square enclosure of the camera and lift upward to unhook the camera unit from the motherboard.
  9. Oregon Scientific Meep! X2 Screen Replacement: 步骤 9 中的图像 1,2 Oregon Scientific Meep! X2 Screen Replacement: 步骤 9 中的图像 2,2
    • Pry the second camera out of its slot with one of the plastic opening tools.
    • Be sure to undo the black adhesive foam from the metal casing in order to remove the camera properly.
  10. Oregon Scientific Meep! X2 Screen Replacement: 步骤 10 中的图像 1,1
    • Release the black security clip on the ribbon cable with your plastic opening tool.
    • Gently disconnect the gold ribbon cable from the motherboard. The two cameras will remain attached to the ribbon cable.
  11. Oregon Scientific Meep! X2 Screen Replacement, Motherboard: 步骤 11 中的图像 1,2 Oregon Scientific Meep! X2 Screen Replacement, Motherboard: 步骤 11 中的图像 2,2
    • Undo the security clips on the ribbon cable connection by placing the plastic opening tool between the black and white parts of the clip. Pull downard toward the gold ribbon cable.
    • Once the left and right clips are undone, remove the gold ribbon cable from that connection by gently pulling it out.
  12. Oregon Scientific Meep! X2 Screen Replacement: 步骤 12 中的图像 1,2 Oregon Scientific Meep! X2 Screen Replacement: 步骤 12 中的图像 2,2
    • Remove the two phillips #00 (4.5mm x 3mm)screws located on the motherboard.
  13. Oregon Scientific Meep! X2 Screen Replacement: 步骤 13 中的图像 1,2 Oregon Scientific Meep! X2 Screen Replacement: 步骤 13 中的图像 2,2
    • Lift the silver, rectangular blocker in order to expose the right phillips screw #00 (4mm x 3.5mm).
    • Unscrew the left and right phillips #00 (4mm x 3.5mm)screws.
    • Once unscrewed, gently lift the motherboard from the rest of the device.
  14. Oregon Scientific Meep! X2 Screen Replacement, Remove the ribbon cable.: 步骤 14 中的图像 1,3 Oregon Scientific Meep! X2 Screen Replacement, Remove the ribbon cable.: 步骤 14 中的图像 2,3 Oregon Scientific Meep! X2 Screen Replacement, Remove the ribbon cable.: 步骤 14 中的图像 3,3
    • Gently unhook the black security clips to loosen the ribbon cable. Use one of the plastic opening tools.
    • Pull lightly on the ribbon cable to remove it.
  15. Oregon Scientific Meep! X2 Screen Replacement, Sever the adhesive glue on the battery.: 步骤 15 中的图像 1,2 Oregon Scientific Meep! X2 Screen Replacement, Sever the adhesive glue on the battery.: 步骤 15 中的图像 2,2
    • Use your spudger to separate the battery from the adhesive glue strips and plastic film.
  16. Oregon Scientific Meep! X2 Screen Replacement: 步骤 16 中的图像 1,2 Oregon Scientific Meep! X2 Screen Replacement: 步骤 16 中的图像 2,2
    • Use a soldering station to unsolder the battery wires from the motherboard.
  17. Oregon Scientific Meep! X2 Screen Replacement, Screen: 步骤 17 中的图像 1,2 Oregon Scientific Meep! X2 Screen Replacement, Screen: 步骤 17 中的图像 2,2
    • Remove the 10 phillips #00(3.5mm x 4mm) screws around the metal framing of the screen.
    • Leave the clear tape on the back of the screen until you are ready to remove it from the white plastic casing.
  18. Oregon Scientific Meep! X2 Screen Replacement: 步骤 18 中的图像 1,2 Oregon Scientific Meep! X2 Screen Replacement: 步骤 18 中的图像 2,2
    • Slowly remove the metal frame and screen from the white casing by gently pulling up on the ends of the metal frame.
  19. Oregon Scientific Meep! X2 Screen Replacement: 步骤 19 中的图像 1,1
    • Remove the plastic tape from the back of the screen.
    • Carefully separate the screen from the metal framing.
结论
J'mel Henneman
于01/20/15注册
864 声望
创作了8篇指南
团队
USF Tampa, Team 9-1, Blackwell Winter 2015 USF Tampa, Team 9-1, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S9G1
3 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 27
总计 1,157
