跳转到主内容
Oregon Scientific Meep! X2 Cameras Replacement
你所需要的
  1. Oregon Scientific Meep! X2 Cameras Replacement, Rear Casing: 步骤 1 中的图像 1,1
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. Oregon Scientific Meep! X2 Cameras Replacement: 步骤 2 中的图像 1,3 Oregon Scientific Meep! X2 Cameras Replacement: 步骤 2 中的图像 2,3 Oregon Scientific Meep! X2 Cameras Replacement: 步骤 2 中的图像 3,3
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Oregon Scientific Meep! X2 Cameras Replacement: 步骤 3 中的图像 1,3 Oregon Scientific Meep! X2 Cameras Replacement: 步骤 3 中的图像 2,3 Oregon Scientific Meep! X2 Cameras Replacement: 步骤 3 中的图像 3,3
    • Use the plastic opening tools to undo the clips around the edges of the device.
  4. Oregon Scientific Meep! X2 Cameras Replacement, Cameras: 步骤 4 中的图像 1,2 Oregon Scientific Meep! X2 Cameras Replacement, Cameras: 步骤 4 中的图像 2,2
    • Slip the plastic opening tool under the white, square enclosure of the camera and lift upward to unhook the camera unit from the motherboard.
  5. Oregon Scientific Meep! X2 Cameras Replacement: 步骤 5 中的图像 1,2 Oregon Scientific Meep! X2 Cameras Replacement: 步骤 5 中的图像 2,2
    • Pry the second camera out of its slot with one of the plastic opening tools.
    • Be sure to undo the black adhesive foam from the metal casing in order to remove the camera properly.
  6. Oregon Scientific Meep! X2 Cameras Replacement: 步骤 6 中的图像 1,1
    • Release the black security clip on the ribbon cable with your plastic opening tool.
    • Gently disconnect the gold ribbon cable from the motherboard. The two cameras will remain attached to the ribbon cable.
结论
J'mel Henneman
于01/20/15注册
864 声望
创作了8篇指南
团队
USF Tampa, Team 9-1, Blackwell Winter 2015 USF Tampa, Team 9-1, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S9G1
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 197
