简介
The Oregon Scientific is a great clock with projection and weather station. Unfortunately, the projection digits failed over time and started fading away.
I tried to fix the segments and reposition the connecting strip connecting the LCD used for projection, the fix FAILED but I ended up with a new functionality - a weather station that projects Mars planet on my ceiling.
你所需要的
Instead of showing the clock/weather in the projection, you'll end up to see a large red disc.
This is going to REPLACE the existing functionality and is most likely not undoable.
Proceed at your own risk!
Gently pry open the front case of the projector module.
Undo the 6 screws using a small Phillips screwdriver and remove the cover.
Pull on the projection assembly to detach it from the case. The top part, containing the lens is detachable by hand, the bottom one has 3 clips and a nut that secures it.
Using a flat screwdriver/pryer press on the tabs on both sides of the assembly to make them loose.
Gently press on the upper piece of plastic, to the top.
Unscrew the large nut.
After you disassemble the projector case, you can see the projector light, the passthrough display and the board that powers it.
You have 2 options:
Try to remove the connecting flex cable between the display and the board and replace it/repair it or clean the contacts on both ends. [I have tried this without success as the wires ripped off because they were aged]
Remove the display from the position (with or without removing the flex cable) and allow the projecting light to go through the lens directly - this way you obtain a big round red light: Mars on your wall!
