跳转到主内容
Ordro HDV-D395 Lens Replacement
你所需要的
  1. Ordro HDV-D395 Lens Replacement, Lens: 步骤 1 中的图像 1,2 Ordro HDV-D395 Lens Replacement, Lens: 步骤 1 中的图像 2,2
    • Pull the slider labeled open, on the bottom right, to unlock the battery.
  2. Ordro HDV-D395 Lens Replacement: 步骤 2 中的图像 1,1
    • Pull battery out of slot.
  3. Ordro HDV-D395 Lens Replacement: 步骤 3 中的图像 1,1
    • Remove the three screws (length 7.7 mm) from the bottom of the outer case using a JIS000 screwdriver.
  4. Ordro HDV-D395 Lens Replacement: 步骤 4 中的图像 1,2 Ordro HDV-D395 Lens Replacement: 步骤 4 中的图像 2,2
    • Remove plastic casing hiding screws from the strap side of the casing.
    • Unscrew the three screws (length 4.75 mm) using a PH000 screwdriver.
    • Unscrew the two screws (length 6.4 mm) using a JIS000 screwdriver.
  5. Ordro HDV-D395 Lens Replacement: 步骤 5 中的图像 1,1
    • Unscrew the four screws (2.9 mm length) from the screen side of the casing using a JIS000 screwdriver.
  6. Ordro HDV-D395 Lens Replacement: 步骤 6 中的图像 1,1
    • Remove both side casings by gripping the sides with your hands and pulling gently.
  7. Ordro HDV-D395 Lens Replacement: 步骤 7 中的图像 1,3 Ordro HDV-D395 Lens Replacement: 步骤 7 中的图像 2,3 Ordro HDV-D395 Lens Replacement: 步骤 7 中的图像 3,3
    • Although it requires extra steps, it is advised that you remove the motherboard and screen to ensure that nothing is damaged in the process of replacing the lens.
    • Unscrew the seven screws (length 4.22 mm) from the motherboard using a PH000 screwdriver.
    • Pull out or desolder all connected cords from motherboard.
  8. Ordro HDV-D395 Lens Replacement: 步骤 8 中的图像 1,2 Ordro HDV-D395 Lens Replacement: 步骤 8 中的图像 2,2
    • Remove top of the casing to reveal the screws on lens.
    • Unscrew the four screws (size 4.90 mm) using a PH00 screwdriver.
  9. Ordro HDV-D395 Lens Replacement: 步骤 9 中的图像 1,3 Ordro HDV-D395 Lens Replacement: 步骤 9 中的图像 2,3 Ordro HDV-D395 Lens Replacement: 步骤 9 中的图像 3,3
    • Pull out lens.
    • Remove cord from lens.
结论
Nathan Mcintyre
于11/05/18注册
303 声望
创作了2篇指南
团队
IUPUI, Team S1-G3, Baechle Fall 2018 IUPUI, Team S1-G3, Baechle Fall 2018 的会员
IUPUI-BAECHLE-F18S1G3
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 183
