你所需要的
Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
Remove the anti-static wrist strap.
Use the Phillips #000 screwdriver to remove the five black 2 mm screws.
Use the Phillips #000 screwdriver to remove the two grey 2 mm screws.
即将完成!
结论
