Parts
No parts specified.
This step is untranslated. Help translate it
Remove the brush head by pulling the top away from the base.
Pry open the end cap from the toothbrush body.
Remove the spring.
Apply pressure on the brush shaft to release the toothbrush internals.
Remove the internals through the bottom of the toothbrush body.
Use flat head screwdriver to remove power button pressure plate.
Desolder the coil wire from the motherboard.
Squeeze and remove coil from motherboard.
Desolder the motor from motherboard.
Remove motherboard and battery from body of toothbrush internals.
Desolder the battery connections from the motherboard.
Remove motherboard from battery holder.
2 other people completed this guide.
