跳转到主内容
加入维修社区 - 创建账户
Optoma PRO360W Bulb Replacement
你所需要的
  1. Optoma PRO360W Bulb Replacement, Unplug projector: 步骤 1 中的图像 1,1
    • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
  2. Optoma PRO360W Bulb Replacement: 步骤 2 中的图像 1,1
    • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
  3. Optoma PRO360W Bulb Replacement: 步骤 3 中的图像 1,1
    • Unscrew the bulb screws on either side of the silver plate.
  4. Optoma PRO360W Bulb Replacement: 步骤 4 中的图像 1,1
    • Remove the light bulb from the projector by lifting the silver handle and pulling up.
  5. Optoma PRO360W Bulb Replacement: 步骤 5 中的图像 1,1
    • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
  6. Optoma PRO360W Bulb Replacement: 步骤 6 中的图像 1,1
    • Use a new Q-tip to clean the fan blades and hole in which the light enters.
  7. Optoma PRO360W Bulb Replacement: 步骤 7 中的图像 1,1
    • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
  8. Optoma PRO360W Bulb Replacement: 步骤 8 中的图像 1,1
    • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
  9. Optoma PRO360W Bulb Replacement: 步骤 9 中的图像 1,1
    • Dispose of the bulb by sending it to a recycling center.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
另外一个人完成了本指南。
Desiree Benitez
于01/21/17注册
128 声望
撰写一个指南
团队
1指南评论
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 36
总计 1,019
