跳转到主内容
Optoma HD20 Light Bulb Replacement
你所需要的
  1. Optoma HD20 Light Bulb Replacement, Rear Panel: 步骤 1 中的图像 1,2 Optoma HD20 Light Bulb Replacement, Rear Panel: 步骤 1 中的图像 2,2
    • Use a Phillips #1 screwdriver to loosen the screws that secure the panel on the bottom of the Optoma HD20.
  2. Optoma HD20 Light Bulb Replacement: 步骤 2 中的图像 1,1
    • Lift the panel off of the device.
  3. Optoma HD20 Light Bulb Replacement, Light Bulb Casing: 步骤 3 中的图像 1,1
    • Use a Phillips #1 screwdriver to loosen the two screws securing the black casing.
    • The screws don't come out all the way.
  4. Optoma HD20 Light Bulb Replacement: 步骤 4 中的图像 1,3 Optoma HD20 Light Bulb Replacement: 步骤 4 中的图像 2,3 Optoma HD20 Light Bulb Replacement: 步骤 4 中的图像 3,3
    • Remove the light bulb casing from the device.
    • Steps 5-9 are unnecessary if the replacement light bulb comes with housing.
  5. Optoma HD20 Light Bulb Replacement, Light Bulb: 步骤 5 中的图像 1,1
    • Remove the three 4.5 mm screws on the light bulb case.
  6. Optoma HD20 Light Bulb Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the light bulb insulator from the light bulb casing.
  7. Optoma HD20 Light Bulb Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Gently pull the wires off of the pins using tweezers.
  8. Optoma HD20 Light Bulb Replacement: 步骤 8 中的图像 1,1
    • Remove the 4 screws on the back of the light bulb casing using a Phillips #1 screwdriver.
  9. Optoma HD20 Light Bulb Replacement: 步骤 9 中的图像 1,2 Optoma HD20 Light Bulb Replacement: 步骤 9 中的图像 2,2
    • Remove the casing, then gently pull out the old light bulb and replace it with the new one.
结论
7等其他人完成本指南。
Trever
于01/22/15注册
1,264 声望
创作了6篇指南
团队
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G23
4 名成员
创作了6篇指南
5条评论
I recently replaced my bulb for the third time and the insulator had grown brittle I am guessing from the heat and it broke. I can't seem to find this part for sale anywhere. Does anyone know if is possible to purchase it?
Thomas - 回复
The screws in step 8 are extremely hard to get off. I went and bought proper screwdrivers before even attempting since theyre small, but in a day I've only managed to get one off and I'm having to resort to other tactics, even using a drill to just grind the heads off.
dv01_ - 回复
king@okinlamps.com
Need LAD60 20PCS
kingshen92 - 回复
The manual says the new light won’t come back on until a lamp reset I’d done via menu , but how can you see the text if the light isn’t on?????
Taringajohn - 回复
my hd 20 projects dull images i recently replaced my bulb for the first time successfully and i followed as per menu trying to bulb reset but it is not working and still image is dull how to solve the problem
kumar - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 72
总计 11,479
