跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Optical Bay Enclosure Dual Hard Drive Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
  1. Optical Bay Enclosure Dual Hard Drive Replacement, Dual Hard Drive: 步骤 1 中的图像 1,2 Optical Bay Enclosure Dual Hard Drive Replacement, Dual Hard Drive: 步骤 1 中的图像 2,2
    • Remove the plastic positioner from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
  2. Optical Bay Enclosure Dual Hard Drive Replacement: 步骤 2 中的图像 1,3 Optical Bay Enclosure Dual Hard Drive Replacement: 步骤 2 中的图像 2,3 Optical Bay Enclosure Dual Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
  3. Optical Bay Enclosure Dual Hard Drive Replacement: 步骤 3 中的图像 1,2 Optical Bay Enclosure Dual Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Once the hard drive is snug, reinsert the plastic positioner while holding the hard drive against the bottom of the enclosure.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
结论
另外一个人完成了本指南。
Brittany McCrigler
于03/05/12注册
88,930 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,718篇指南
一条评论
Great guide, however I think you overestimated the difficulty of it. The biggest challenge is not stripping any screws and being sure to have all sizes that you may possibly need including some that might not be standard because stripping screws is very possible. Otherwise, nice job
Rob Anthony Dire - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 247
