跳转到主内容
Oppo X9000 Chassis Replacement
你所需要的
  1. Oppo X9000 Chassis Replacement, Removing the Back Cover: 步骤 1 中的图像 1,2 Oppo X9000 Chassis Replacement, Removing the Back Cover: 步骤 1 中的图像 2,2
    • Turn the phone over so that you are facing the back side of the phone.
    • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
    • Completely remove the back cover by moving down the sides and bottom with your fingers.
  2. Oppo X9000 Chassis Replacement, Removing the Battery: 步骤 2 中的图像 1,1
    • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
  3. Oppo X9000 Chassis Replacement, Remove the Back Panel Screws: 步骤 3 中的图像 1,2 Oppo X9000 Chassis Replacement, Remove the Back Panel Screws: 步骤 3 中的图像 2,2
    • Remove the twelve exposed 3.6 mm Phillips screws on the rear of the phone using the 3.6 mm Phillips screwdriver.
    • Store all the screws in a safe place where you will not lose them.
  4. Oppo X9000 Chassis Replacement, Remove the Rubber Stoppers: 步骤 4 中的图像 1,2 Oppo X9000 Chassis Replacement, Remove the Rubber Stoppers: 步骤 4 中的图像 2,2
    • Remove the three circular rubber screw covers on the back of the phone by slipping the spudger into the border between the rubber cover and the chassis. In one motion, pry the stopper out of the hole. This can take some force.
  5. Oppo X9000 Chassis Replacement, Remove the Newly Exposed Screws: 步骤 5 中的图像 1,1
    • With the 3.6 mm Phillips screwdriver, remove the three newly exposed 3.6mm Phillips screws.
  6. Oppo X9000 Chassis Replacement, Lift off the Back Panel: 步骤 6 中的图像 1,2 Oppo X9000 Chassis Replacement, Lift off the Back Panel: 步骤 6 中的图像 2,2
    • Insert the plastic opening tool underneath the chassis near the power button and pry the chassis from the phone. This should take a little force.
结论
4等其他人完成本指南。
James Kragh
于10/14/14注册
1,605 声望
创作了5篇指南
团队
Cal Poly, Team 4-45, Amido Fall 2014 Cal Poly, Team 4-45, Amido Fall 2014 的会员
CPSU-AMIDO-F14S4G45
5 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 1,853
