跳转到主内容
修复你的物品
维修的权力
配件 & 工具
  1. 这个步骤还没有翻译 帮忙翻译一下
    Exterior reference shots. Exterior reference shots. Exterior reference shots.
    • Exterior reference shots.
  2. 这个步骤还没有翻译 帮忙翻译一下
    T2 Torx screws appear to secure the display, but removing them doesn't seem to make its removal any easier. Very strong clips secure the interior of the phone to the stiff metal rear case.
    • T2 Torx screws appear to secure the display, but removing them doesn't seem to make its removal any easier.
    • Very strong clips secure the interior of the phone to the stiff metal rear case.
  3. 这个步骤还没有翻译 帮忙翻译一下
    Nothing on the rear case.
    • Nothing on the rear case.
    • Battery immediately accessible.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. 这个步骤还没有翻译 帮忙翻译一下
    Battery pull tab has instructions and works well to peel the battery up. Adhesive is fairly stiff. Battery takes protective sheet with it, revealing interconnect cables.
    • Battery pull tab has instructions and works well to peel the battery up. Adhesive is fairly stiff.
    • Battery takes protective sheet with it, revealing interconnect cables.
  6. 这个步骤还没有翻译 帮忙翻译一下
    After the battery the next available components are:
    • After the battery the next available components are:
    • Antenna interconnect cables.
    • Charging port and cable, very good for repair, individual part, and easily accessible.
    • Various brackets, annoying for reassembly, but standard Phillips #00 screws are a bonus.
  7. 这个步骤还没有翻译 帮忙翻译一下
    The motherboard-daughterboard interconnect cable connects to the underside of the daughterboard, which makes removing the cable or board more difficult. The headphone jack is soldered to the daughterboard, but the board is small and has minimal parts, so it should be an inexpensive replacement component.
    • The motherboard-daughterboard interconnect cable connects to the underside of the daughterboard, which makes removing the cable or board more difficult.
    • The headphone jack is soldered to the daughterboard, but the board is small and has minimal parts, so it should be an inexpensive replacement component.
  8. 这个步骤还没有翻译 帮忙翻译一下
    Motherboard and speaker assembly are now removable. Once the motherboard is removed the following components can be removed: camera bracket, cameras, interconnect cable.
    • Motherboard and speaker assembly are now removable.
    • Once the motherboard is removed the following components can be removed: camera bracket, cameras, interconnect cable.
  9. 这个步骤还没有翻译 帮忙翻译一下
    The display assembly final components are fairly easily removed: home button bracket, home button, button cables, vibrator, earpiece speaker.
    • The display assembly final components are fairly easily removed: home button bracket, home button, button cables, vibrator, earpiece speaker.
    • Including the frame and fused display in the display assembly makes the part more expensive.
  10. 这个步骤还没有翻译 帮忙翻译一下
    The Oppo R9m earns a 7 out of 10 on our repairability scale (10 is the easiest to repair): Battery is fairly easily accessible and removable.
    • The Oppo R9m earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
    • Battery is fairly easily accessible and removable.
    • Most components are extremely modular making for cheaper repairs.
    • The opening procedure is extremely tough, clips are very stiff and likely to be broken.
    • The single unit display assembly is annoying to reach, and will be a costly part.
    • Manufacturer does not provide user-accessible repair documentation.
终点
12等其他人完成本指南。
Sam Goldheart
于2012年10月18日注册
413,565 信誉积分
创作了547篇指南
团队
iFixit iFixit 的会员
Community
124 名成员
创作了11,798篇指南
need stuff like pin unlock etc
callgoldengaia - 回复
Good and nice thankyou
OPPOSUPPORT - 回复
Can I get the mother board of oppo a37
Aryan Bunde - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 10
过去的30天: 66
总计 5,758
