跳转到主内容
Opening the Tesco hudl2 case
你所需要的
视频概述
  1. Opening the Tesco hudl2 case, Open the case: 步骤 1 中的图像 1,2 Opening the Tesco hudl2 case, Open the case: 步骤 1 中的图像 2,2
    • Take your time!
    • Use a guitar pick, although some have successfully used a fingernail. Don't use a screwdriver as you will damage the case.
    • Start at one corner and carefully insert your tool, working it along the seam until you hear a click and the case starts to come apart.
    • Carry on working your way around the case. Be very careful near the buttons.
    • Eventually the rear case will come away. There aren't any wires attached to the rear case, it just lifts off.
    • When it's time to reassemble, clip the rear cover back on carefully, making sure to fit the side with the buttons first and being careful to ensure they are positioned correctly.
  2. Opening the Tesco hudl2 case: 步骤 2 中的图像 1,1
    • This is what you will see once the rear case is removed.
终点
另外一个人完成了本指南。
Tim
于08/31/10注册
1,423 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 926
