跳转到主内容
Opening the Sirius SP-B1 Sportster Boombox
你所需要的
  1. Opening the Sirius SP-B1 Sportster Boombox, Outer Case: 步骤 1 中的图像 1,1
    • Begin by unscrewing the four recessed screws in the rear of the boombox. They don't seem to be magnetic, and they may not pop out immediately.
  2. Opening the Sirius SP-B1 Sportster Boombox: 步骤 2 中的图像 1,3 Opening the Sirius SP-B1 Sportster Boombox: 步骤 2 中的图像 2,3 Opening the Sirius SP-B1 Sportster Boombox: 步骤 2 中的图像 3,3
    • Next, you will need to remove the mesh that covers the speakers. Using the flathead screwdriver, start prying near the top or bottom of the mesh, near the center. The 'corners' come up more easily. Once you have part of the mesh pulled out, go around the outside and use indents in the mesh to pry it out. Try not to bend the mesh very much.
  3. Opening the Sirius SP-B1 Sportster Boombox: 步骤 3 中的图像 1,1
    • There are screws now accessible near the bottom of each side under the mesh, near the center of the boombox. Once you remove these, the faceplate will come right off.
  4. Opening the Sirius SP-B1 Sportster Boombox: 步骤 4 中的图像 1,3 Opening the Sirius SP-B1 Sportster Boombox: 步骤 4 中的图像 2,3 Opening the Sirius SP-B1 Sportster Boombox: 步骤 4 中的图像 3,3
    • Now you can get to some of the electronic components. Only eight screws separate you from the inside of the boombox. Undo the screws and fix up the inside to your heart's content.
结论
2等其他人完成本指南。
sonori
于06/13/11注册
195 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,158
