跳转到主内容
Opening the Samsung Galaxy Watch Active
你所需要的
  1. Opening the Samsung Galaxy Watch Active, Turn off the watch: 步骤 1 中的图像 1,2 Opening the Samsung Galaxy Watch Active, Turn off the watch: 步骤 1 中的图像 2,2
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Opening the Samsung Galaxy Watch Active, Remove the rear screws: 步骤 2 中的图像 1,1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Opening the Samsung Galaxy Watch Active, Separate the back cover from the housing: 步骤 3 中的图像 1,3 Opening the Samsung Galaxy Watch Active, Separate the back cover from the housing: 步骤 3 中的图像 2,3 Opening the Samsung Galaxy Watch Active, Separate the back cover from the housing: 步骤 3 中的图像 3,3
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Opening the Samsung Galaxy Watch Active, Disconnect the sensor array: 步骤 4 中的图像 1,2 Opening the Samsung Galaxy Watch Active, Disconnect the sensor array: 步骤 4 中的图像 2,2
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Opening the Samsung Galaxy Watch Active, Remove the back cover: 步骤 5 中的图像 1,1
    • Remove the back cover.
结论
11等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
117,296 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,521篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 110
过去 30 天: 491
总计 16,289
