简介
Opening the hood is required to access the engine bay and perform many vehicle maintenance tasks.
Locate the hood latch beside the driver's side door, next to the left foot rest.
Pull the latch toward you to release the hood.
4等其他人完成本指南。
一条评论
Whats next after opening the hood? How to check for the hood latch? Where is it located? Need to check for the cause why the alarm keeps going
off at odd hours. The car has lojack and a car alarm. Changed the FOB key that didnt worked. Manually opened the door with key. Not happening problem still exist. Need help with what other options.
boomanison - 回复
I change my oil every 5.000 miles like clockwork I did a compression test a few weeks ago and it's only lost about 2% of it compression and done 160.000 miles so well worth it
Graham Wells - 回复
What if u can’t get inside to unlock the hood
Paula Charron - 回复
My fob is not working properly I guess I checked the battery and it’s good still won’t open car a Sonata hybrid 2021 what do I do?
Paula Charron - 回复
