跳转到主内容
你所需要的
  1. Opening the Galaxy Watch3, Unfasten the back cover screws: 步骤 1 中的图像 1,1
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
  2. Opening the Galaxy Watch3, Wedge open the back cover: 步骤 2 中的图像 1,2 Opening the Galaxy Watch3, Wedge open the back cover: 步骤 2 中的图像 2,2
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
  3. Opening the Galaxy Watch3, Disconnect the sensor flex cable: 步骤 3 中的图像 1,3 Opening the Galaxy Watch3, Disconnect the sensor flex cable: 步骤 3 中的图像 2,3 Opening the Galaxy Watch3, Disconnect the sensor flex cable: 步骤 3 中的图像 3,3
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  4. Opening the Galaxy Watch3, Remove the back cover: 步骤 4 中的图像 1,2 Opening the Galaxy Watch3, Remove the back cover: 步骤 4 中的图像 2,2
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
结论
Tobias Isakeit
于2014年03月31日注册
105,580 声望
创作了184篇指南
团队
iFixit iFixit 的会员
Community
141 名成员
创作了15,836篇指南
2条评论
where can I get the galaxy watch3 rubber gasket?
regards
Miguel Vera - 回复
That’s a good question. As for the previous models it is very hard to find those rubber gaskets. Using a “liquid rubber gasket” might be one solution to that. (Use carefully to not spill too much on and into the watch)
Tobias Isakeit -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 51
总计 1,118
