跳转到主内容
加入维修社区 - 创建账户
Opening the Computer (2006-2008)
你所需要的
  1. Opening the Computer (2006-2008), Opening the Computer (2006-2008): 步骤 1 中的图像 1,2 Opening the Computer (2006-2008), Opening the Computer (2006-2008): 步骤 1 中的图像 2,2
    • Shut down the computer.
    • Warning: Always shut down the computer before opening it to avoid damaging its internal components or the components you are installing. Do not open the computer or attempt to install items inside it while it is on.
    • Wait 5 to 10 minutes to allow the computer’s internal components to cool.
    • Warning: After you shut down the system, the internal components can be very hot. You must let the computer cool down before continuing.
    • Unplug all external cables from the computer except the power cord.
    • Touch the metal PCI access covers on the back of the computer to discharge any static electricity from your body.
    • Unplug the power cord.
    • Put on an ESD wrist strap.
  2. Opening the Computer (2006-2008): 步骤 2 中的图像 1,1
    • 1) Hold the side access panel and lift the latch on the back of the computer.
    • Warning: The edges of the access panel and the enclosure can be sharp. Be very careful when handling them.
    • 2) Remove the access panel and place it on a flat surface covered by a soft, clean cloth.
    • Replacement Note: Make sure the latch is in the up position before replacing the access panel. If the latch is down, the access panel will not seat correctly in the enclosure.
结论
13等其他人完成本指南。
Joshua Byrne
于05/03/13注册
7,866 声望
创作了10篇指南
2指南评论
Do you have information on  Mac Pro Tower 2008 latch mechanism replacement #.
When can I buy this?
v h - 回复
Hola buenos días. Tengo una y soy de Venezuela me gustaría saber cómo conseguir este procesador Xeon x5492
Videos premium - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 32
过去 30 天: 105
总计 10,514
