跳转到主内容
Opening the Column in the Hamilton Galileo
你所需要的
  1. Opening the Column in the Hamilton Galileo, Opening the Column in the Hamilton Galileo: 步骤 1 中的图像 1,1
    • Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
    • Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
  2. Opening the Column in the Hamilton Galileo: 步骤 3 中的图像 1,1
    • Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
  3. Opening the Column in the Hamilton Galileo: 步骤 4 中的图像 1,2 Opening the Column in the Hamilton Galileo: 步骤 4 中的图像 2,2
    • Without removing any electrical connections, open the left side of the column as wide as practical.
    • This exposes: GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    • Make sure no electrical connections are touching the column.
    • Make sure all green/brown grounding (earthing) cables are securely in place.
结论
Ian Van Sciver
于04/09/20注册
332 声望
创作了2篇指南
团队
Cal Poly, Team S7-G26, Paton Spring 2020 Cal Poly, Team S7-G26, Paton Spring 2020 的会员
CPSU-PATON-S20S7G26
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 114
