跳转到主内容
加入维修社区 - 创建账户
Opening and repairing Petzl Tikka Plus 4 LED Headlamp
你所需要的
  1. Opening and repairing Petzl Tikka Plus 4 LED Headlamp, Open battery compartment: 步骤 1 中的图像 1,1
    • Push the catch on the top to open the battery compartment
    询问修复机器人
    添加评论
  2. Opening and repairing Petzl Tikka Plus 4 LED Headlamp, Remove battery cover: 步骤 2 中的图像 1,1
    • Remove the batteries and lift the two straps with a flat screwdriver. Pull the straps out.
    询问修复机器人
    添加评论
  3. Opening and repairing Petzl Tikka Plus 4 LED Headlamp, Extract PCB and battery holder: 步骤 3 中的图像 1,1
    • This is the most crucial part. Do NOT try to release the latches at the front. Insert a small screwdriver at the positions indicated in the back near the "belt hinges" to flex the rear part of the case back and free the latches of the inner part.
    添加评论
  4. Opening and repairing Petzl Tikka Plus 4 LED Headlamp, Disassembled parts: 步骤 4 中的图像 1,3 Opening and repairing Petzl Tikka Plus 4 LED Headlamp, Disassembled parts: 步骤 4 中的图像 2,3 Opening and repairing Petzl Tikka Plus 4 LED Headlamp, Disassembled parts: 步骤 4 中的图像 3,3
    • If all went well, the inner part should come out. In my case the push button fell into its pieces as well. You see the rubber layer and sheet metal clip of the button in the orange back of the outer knob.
    • The push button itself is a smd device of 6mm x 6mm and about 3.1mm height. The best thing would be to replace it. If you can get a spare part and can solder these tiny pads go for it. I just cleaned the dome spring with a piece of paper and reassembled it. Make sure you place the concave side of the dome spring on the three connectors.
    • Before reassembly try to insert batteries and verify that connecting the middle pole of the button to one of the outer ones switches the light on. Dont look straight into the LEDs, they're very bright!
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
11等其他人完成本指南。
Toby
于10/26/15注册
367 声望
撰写一个指南
8指南评论
thanks needed this.
Matt chu - 回复 分享
With minor modification this guide is suitable for other Petzl torches.
Heinz de Chelard - 回复 分享
How do you strap the headband after taking it off…silly question but any info would be helpful
Jeffrey Smith - 回复 分享
I have a 3-LED Tikka and this guide worked the same. After many years, I was finally able to fix the screwy slider on-off switch contact with the lead on the little resistor. Whoohoo! It works fine now.
John - 回复 分享
Like John, worked for 3 LED Tikka. Battery leaked all over the contacts and I was able to clean it and get it back up and running.
Jesse - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 70
过去 30 天: 309
总计 34,704
