跳转到主内容
Opening PowerMac G4 M5183 Case
  1. Opening PowerMac G4 M5183 Case, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 1,2 Opening PowerMac G4 M5183 Case, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 2,2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Fino a li lo intuisce anche un bambino. Io volevo sapere come levare l'altro sportello senza rompere niente. Ma una vodtra risposta non la vedo.
    giorgus - 回复
终点
16等其他人完成本指南。
Justin Petrilli
于01/21/10注册
3,114 声望
创作了11篇指南
团队
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G24
4 名成员
创作了25篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 77
总计 19,265
