跳转到主内容
Opening Philips Senseo Quadrante
你所需要的
  1. Opening Philips Senseo Quadrante, Opening Philips Senseo Quadrante: 步骤 1 中的图像 1,2 Opening Philips Senseo Quadrante, Opening Philips Senseo Quadrante: 步骤 1 中的图像 2,2
    • Never forget: Power off and unplug your device before starting repairs!
    • Remove all attachments such as cup rack, pod holder and water tank.
  2. Opening Philips Senseo Quadrante: 步骤 2 中的图像 1,1
    • Turn the device so that the rear of the machine is facing you.
    • Remove the two Torx T15 screws at the bottom on the machine.
  3. Opening Philips Senseo Quadrante: 步骤 3 中的图像 1,1
    • The side panel must first be detached at the bottom edge. Turn the machine so that the bottom is facing towards you.
    • There are two indentations on the base plate with catches inside each one. Press in the catches with a screwdriver and detach the side panel at the bottom edge.
    • Chances are the plate will get stuck. It is recommended that you use a plastic pry tool to avoid scratching.
  4. Opening Philips Senseo Quadrante: 步骤 4 中的图像 1,2 Opening Philips Senseo Quadrante: 步骤 4 中的图像 2,2
    • At this point, the side panel is still snapped into place on the front, right next to the coffee spout. You can use a screwdriver to carefully pry the latch open.
    • On the inside of the side panel there are two pegs on the top edge that fit in the holes. Lift the side panel up and out.
  5. Opening Philips Senseo Quadrante: 步骤 5 中的图像 1,1
    • The heating element can be seen immediately after the side panel is removed.
  6. Opening Philips Senseo Quadrante: 步骤 6 中的图像 1,3 Opening Philips Senseo Quadrante: 步骤 6 中的图像 2,3 Opening Philips Senseo Quadrante: 步骤 6 中的图像 3,3
    • User a screwdriver to release the catch at the top of the electronics cover.
    • Lift out the cover.
    • Both the electronics and the pump will be visible once the cover is removed.
结论
Follow the steps in reverse order to reassemble your device.
9等其他人完成本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
VauWeh
于10/19/15注册
297,278 声望
创作了303篇指南
1指南评论
Descriptifs et photos des opérations bien détaillés, pour mon HD 7864.
Un petit détail pour le démontage du disque de distribution d'eau il y a une encoche avec 2 flèches face à face, faire levier avec petit tournevis pour le déclipser. Merci bonne continuation 😉👍
Gerard - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 151
过去 30 天: 701
总计 19,732
