跳转到主内容
Opening DXG 567V HD Camera Case
你所需要的
  1. Opening DXG 567V HD Camera Case, Opening DXG 567V HD Camera Case: 步骤 1 中的图像 1,2 Opening DXG 567V HD Camera Case, Opening DXG 567V HD Camera Case: 步骤 1 中的图像 2,2
    • This camcorder is a 720p HD camcorder that costs very little.
  2. Opening DXG 567V HD Camera Case: 步骤 2 中的图像 1,2 Opening DXG 567V HD Camera Case: 步骤 2 中的图像 2,2
    • The first step is to open the hatch for the batteries. to do this, on the right side there is a door that you push down on and it opens.
    • Now remove the two s screws highlighted in red.
  3. Opening DXG 567V HD Camera Case: 步骤 3 中的图像 1,1
    • Now at the bottom of the device there is a screw circled in red that is hidden under a warranty sticker (in blue).
    • THIS STEP WILL VOID YOUR WARRANTY!
  4. Opening DXG 567V HD Camera Case: 步骤 4 中的图像 1,1
    • On the top side there is a screw (circled) that is under a little black dot. Peel that dot off with a knife or pointed spudger.
  5. Opening DXG 567V HD Camera Case: 步骤 5 中的图像 1,1
    • On the left side there is another screw under the black dot.
  6. Opening DXG 567V HD Camera Case: 步骤 6 中的图像 1,1
    • On the right side (battery door hatch side), there is another screw under a black dot.
  7. Opening DXG 567V HD Camera Case: 步骤 7 中的图像 1,1
    • Now carefully using a spudger or case opening tool, carefully rise the front bezel from the back casing by working around the device.
  8. Opening DXG 567V HD Camera Case: 步骤 8 中的图像 1,1
    • When lifting the front off the hatch for the batteries will come off. when putting it back together put the spring (in green) in between the rail holders (in red) then slip it on the rail (yellow).
结论
toddsifix
于07/09/12注册
160 声望
撰写一个指南
团队
iFix iFix 的会员
Community
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,185
