简介
Oontz Angle 3 is a wireless Bluetooth speaker manufactured by Cambridge SoundWorks. It's main features are compact size, along with rubber casing, which makes it dustproof, sandproof and splashproof. Its normal output power is 10 Watts. The battery capacity is 2200 mAh, which helps this speaker work for at least 7 hours with one full charge.
你所需要的
Use the plastic opening tool to remove the rubber caps from each end of the speaker.
另外一个人完成了本指南。
