本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to fix your button pins if they are crooked.
你所需要的
Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws.
You will see that each button on the face plate has a button pin that presses the corresponding button on the logic board. Visually check if any of these pins are bent or broken.
即将完成!
结论
