跳转到主内容
加入维修社区 - 创建账户
OnePlus 8 Pro Battery Replacement
你所需要的
  1. OnePlus 8 Pro Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Heat up the back edge of the phone with the iOpener / any HotPack.
    • Start with a long edge as it is easier to open the back cover in the next step.
    • You may also use a hair dryer or heat gun to heat the adhesive.
    • Be careful not to overheat the phone - the screen and internal battery are susceptible to heat damage.
  2. OnePlus 8 Pro Battery Replacement: 步骤 2 中的图像 1,1
    • Insert the opening pick in the middle of the phone where you heated it. Slide it along the edge to cut through the adhesive.
    • This can be a bit tricky, don't use any sharp objects as you can damage the case. It's reccomended that you use a plastic wedge tool such as the one by iFixit, as it has a thicker ledge to prevent you from slicing too far in.
    • If it does not work, try heating the edge again.
    • Don't insert the opening pick too far. There are no flex cables in the way, but the wireless charging coil could be damaged.
  3. OnePlus 8 Pro Battery Replacement: 步骤 3 中的图像 1,2 OnePlus 8 Pro Battery Replacement: 步骤 3 中的图像 2,2
    • Leave the opening picks once you managed to open one side.
    • Use heat on the next edge to open it.
    • Repeat steps 2 and 3 for all four edges.
  4. OnePlus 8 Pro Battery Replacement: 步骤 4 中的图像 1,1
    • Remove these screws (Phillips 00).
    • Remove this Phillips 00 screw. You can remove the white paper with tweezers or just push the screwdriver through the paper.
  5. OnePlus 8 Pro Battery Replacement: 步骤 5 中的图像 1,2 OnePlus 8 Pro Battery Replacement: 步骤 5 中的图像 2,2
    • Carefully lift the two stickers which hold the wireless charging coil down.
  6. OnePlus 8 Pro Battery Replacement: 步骤 6 中的图像 1,1
    • Lift the charging coil.
    • Remove the two Phillips 00 screws below the coil.
  7. OnePlus 8 Pro Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the top cover / coil assembly.
  8. OnePlus 8 Pro Battery Replacement: 步骤 8 中的图像 1,1
    • Disconnect the battery.
  9. OnePlus 8 Pro Battery Replacement: 步骤 9 中的图像 1,1
    • Pull the red pulling tab away from the battery.
    • Separate the red pulling tab from the black adhesive.
    • After separating, hold the black adhesive down and pull the red tab up vertically to remove the battery.
    • Make sure not to bend the battery too heavily.
  10. OnePlus 8 Pro Battery Replacement: 步骤 10 中的图像 1,2 OnePlus 8 Pro Battery Replacement: 步骤 10 中的图像 2,2
    • Remove the red pulling tab from the old battery and stick it on the under side of the new battery.
    • This makes it easier to replace the battery again.
    • Insert the new battery.
    • Wrap the black adhesive strips on both sides around the battery to secure it.
  11. OnePlus 8 Pro Battery Replacement: 步骤 11 中的图像 1,1
    • Remove the old adhesive and replace it with new adhesive strips.
    • Reverse from step 8 to assemble the phone.
结论
Manuel Graf
于01/21/20注册
193 声望
撰写一个指南
1指南评论
be carefull: the adhesives of the back cover are not only on the edge, but also on the 4 corners (see the back cover on photo of step 4). You should carefully cut these off from the short edges, BEFORE trying to lift the cover.
LeFils - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 40
过去 30 天: 192
总计 1,889
