跳转到主内容
OnePlus 7 Pro Battery Replacement
你所需要的
  1. 注意:步骤 1-8 源自标记为进行中的 指南
    OnePlus 7 Pro Battery Replacement, OnePlus 7 Pro Battery Cover  Replacement: 步骤 1 中的图像 1,3 OnePlus 7 Pro Battery Replacement, OnePlus 7 Pro Battery Cover  Replacement: 步骤 1 中的图像 2,3 OnePlus 7 Pro Battery Replacement, OnePlus 7 Pro Battery Cover  Replacement: 步骤 1 中的图像 3,3
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. OnePlus 7 Pro Battery Replacement: 步骤 2 中的图像 1,2 OnePlus 7 Pro Battery Replacement: 步骤 2 中的图像 2,2
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
    • An iFixit iOpener, hairdryer, or hot plate can also be used to heat the edges. See the iOpener Heating guide for instructions on using the iOpener.
  3. OnePlus 7 Pro Battery Replacement: 步骤 3 中的图像 1,3 OnePlus 7 Pro Battery Replacement: 步骤 3 中的图像 2,3 OnePlus 7 Pro Battery Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
  4. OnePlus 7 Pro Battery Replacement: 步骤 4 中的图像 1,3 OnePlus 7 Pro Battery Replacement: 步骤 4 中的图像 2,3 OnePlus 7 Pro Battery Replacement: 步骤 4 中的图像 3,3
    • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
  5. OnePlus 7 Pro Battery Replacement: 步骤 5 中的图像 1,2 OnePlus 7 Pro Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the phone's back cover.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
  6. OnePlus 7 Pro Battery Replacement: 步骤 6 中的图像 1,3 OnePlus 7 Pro Battery Replacement: 步骤 6 中的图像 2,3 OnePlus 7 Pro Battery Replacement: 步骤 6 中的图像 3,3
    • Use a pair of tweezers to lift up the piece of black tape covering the laser autofocus and flash flex cable.
    • Use a pair of tweezers to lift and remove the covering on the laser autofocus and flash flex cable.
  7. OnePlus 7 Pro Battery Replacement: 步骤 7 中的图像 1,1
    • Use the flat end of a spudger to disconnect the laser autofocus and flash flex cable.
  8. OnePlus 7 Pro Battery Replacement: 步骤 8 中的图像 1,2 OnePlus 7 Pro Battery Replacement: 步骤 8 中的图像 2,2
    • Peel off the adhesive cover for the new battery cover.
  9. OnePlus 7 Pro Battery Replacement, Remove upper plate: 步骤 9 中的图像 1,1
    • Remove all 14 screws of the upper plate.
    • As soon as all screws are removed, you can take it off with a spudger.
    • One screw is placed underneath a white sticker. You can punch trough the sticker with your screwdriver.
  10. OnePlus 7 Pro Battery Replacement, Disconnect Battery: 步骤 10 中的图像 1,1
    • Disconnect the battery connector with a spudger.
  11. OnePlus 7 Pro Battery Replacement: 步骤 11 中的图像 1,2 OnePlus 7 Pro Battery Replacement: 步骤 11 中的图像 2,2
    • Grab the tab and gently pull the Battery out.
    • The Battery is glued on the bottom side.
结论
To reassemble your device, replace the battery cover and follow these instructions in reverse order.
13等其他人完成本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Fabian Jung
于01/29/22注册
549 声望
撰写一个指南
5条评论
It didnt mention how to open the back cover in the first place? Which is the hardest part and the one that require the most skills and specialized tools.
Abdulaziz Alsaqer - 回复
The article links another article talking about the cover. Both do not cover how to apply the new part, specifically, how to install the new battery in this case. I think vitally important. :) @fabianjung
Chintan Pathak - 回复
DO NOT use the jimmy tool or anything metal to scrape the glue off!!! You will scratch and remove the paint on the back cover!
Dani - 回复
5/10 as a guide IMHO.
Why isn't a replacement adhesive gasket part of the requirements (in addition to the replacement battery)??!
The seal will most likely be severely compromised after being opened.
JayM - 回复
Update: 7/10. Taking the back off went easily/smoothly after lying on a 3D printer bed (@80C) for about 10mins, then using a hot air gun (@90C) and a metal spudger and plastic picks to gently break the adhesive holding the back to the body.
No issue removing the inside cover and pulling out the battery.
Having a replacement adhesive gasket/tape is a good idea when re-assembling though. The original guide didn't mentioned this.
JayM - 回复
添加评论
浏览统计数据:
过去 24 小时: 32
过去 7 天: 223
过去 30 天: 880
总计 28,010
