简介
OnePlus 6T was the flagship killer launched by the Chinese brand in November 2018. One of the major upgrades from its OnePlus 6 model, was the in-screen fingerprint scanner alongside other hardware updates. 6T featured a dual-camera setup at the rear (16+20 MP) and was the best camera launched by the company until the OnePlus 7 in the following year. This post helps you replace that setup and its detailed explanation ensures that you perform this procedure in the best way possible.
你所需要的
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
Carefully remove the SIM card from its tray.
Remove the SIM card tray from the phone. Don't need to remove the actual card from the tray, just be careful you don't lose it…
SayIDidIt™ - 回复
在这个步骤中使用的工具:Plastic Cards$2.99
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
It was sufficient for me to re-heat the adhesive from the phone.
Also, I used a pair of tweezers to lift the initial corner, which was a breeze compared to the Jimmy’s as suggested by the guide.
Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
Use tweezers to remove the battery cover and place it to the side.
Using a spudger, disconnect the two metal rear camera tabs on the left side of the camera.
Remove the camera from its slot on the motherboard.
3等其他人完成本指南。
