跳转到主内容
OnePlus 6T Motherboard Replacement
你所需要的
  1. OnePlus 6T Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
  2. OnePlus 6T Motherboard Replacement: 步骤 2 中的图像 1,1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
  3. OnePlus 6T Motherboard Replacement: 步骤 3 中的图像 1,1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
  4. OnePlus 6T Motherboard Replacement: 步骤 4 中的图像 1,3 OnePlus 6T Motherboard Replacement: 步骤 4 中的图像 2,3 OnePlus 6T Motherboard Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
  5. OnePlus 6T Motherboard Replacement, Front Camera: 步骤 5 中的图像 1,2 OnePlus 6T Motherboard Replacement, Front Camera: 步骤 5 中的图像 2,2
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
  6. OnePlus 6T Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
  7. OnePlus 6T Motherboard Replacement: 步骤 7 中的图像 1,1
    • Using a spudger, gently remove the midframe and place it to the side.
  8. OnePlus 6T Motherboard Replacement: 步骤 8 中的图像 1,1
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
  9. OnePlus 6T Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,2 OnePlus 6T Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Remove the single 3mm Phillips #00 screw to the right of the top rear camera.
  10. OnePlus 6T Motherboard Replacement: 步骤 10 中的图像 1,1
    • Using a spudger, disconnect the charging port flex connector, the main flex connector, and the screen flex connector at the bottom of the camera.
  11. OnePlus 6T Motherboard Replacement: 步骤 11 中的图像 1,1
    • Use a spudger to disconnect the signal cables on the right side of the motherboard.
  12. OnePlus 6T Motherboard Replacement: 步骤 12 中的图像 1,2 OnePlus 6T Motherboard Replacement: 步骤 12 中的图像 2,2
    • Disconnect the slider from the top of the phone with a spudger.
    • The slider is extremely delicate, so it is important you do not attempt to remove it from the sides.
    • Gently pull the motherboard from the left side and remove it from the phone.
结论
3等其他人完成本指南。
Kristen Gismondi
于11/12/14注册
81,748 声望
创作了200篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,767篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 42
总计 3,941
