跳转到主内容
OnePlus 6 Screen Replacement
你所需要的
  1. OnePlus 6 Screen Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
  2. OnePlus 6 Screen Replacement: 步骤 2 中的图像 1,2 OnePlus 6 Screen Replacement: 步骤 2 中的图像 2,2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
  3. OnePlus 6 Screen Replacement: 步骤 3 中的图像 1,2 OnePlus 6 Screen Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
  4. OnePlus 6 Screen Replacement, Battery: 步骤 4 中的图像 1,2 OnePlus 6 Screen Replacement, Battery: 步骤 4 中的图像 2,2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
  5. OnePlus 6 Screen Replacement, Speaker: 步骤 5 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the eight screws.
    • Carefully lift the speaker up and out of the chassis.
    • If you're completing a screen replacement, skip to Step 9.
  6. OnePlus 6 Screen Replacement: 步骤 6 中的图像 1,1
    • Properly orient the new speaker unit and use a Phillips #000 screwdriver to replace the eight screws removed from the previous step.
  7. OnePlus 6 Screen Replacement: 步骤 7 中的图像 1,1
    • Place the battery back into the phone and connect it to the same port, making sure to firmly press the connection down into place.
    • Place the red cover back over the top of the port.
  8. OnePlus 6 Screen Replacement: 步骤 8 中的图像 1,1
    • Strip the existing adhesive, and place new adhesive around the entire perimeter of the back cover.
    • Replace the back cover and hold it down for about a minute to to let the adhesive set.
  9. OnePlus 6 Screen Replacement, Screen: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to gently pull away the tab securing the audio jack to the speaker assembly.
  10. OnePlus 6 Screen Replacement: 步骤 10 中的图像 1,1
    • After removing the band, gently lift the audio jack out of the phone.
  11. OnePlus 6 Screen Replacement: 步骤 11 中的图像 1,2 OnePlus 6 Screen Replacement: 步骤 11 中的图像 2,2
    • Remove the white and black leads by gently lifting them up with tweezers.
    • Lift the band connector on the left side of the assembly up with tweezers to disconnect it.
    • Lift the band connector at the top of the assembly up with tweezers to disconnect it.
  12. OnePlus 6 Screen Replacement: 步骤 12 中的图像 1,1
    • Using tweezers, lift the circuit board from the assembly and remove it.
  13. OnePlus 6 Screen Replacement: 步骤 13 中的图像 1,1
    • Use a heat gun set to its lowest temperature, gently heat the perimeter of the screen to loosen the adhesive.
    • Wedge an opening pick between the screen and the chassis, then slide it around the entire perimeter of the screen to break the adhesive.
    • Gently pry the screen away from the chassis.
    • Reheat the perimeter as needed.
  14. OnePlus 6 Screen Replacement: 步骤 14 中的图像 1,2 OnePlus 6 Screen Replacement: 步骤 14 中的图像 2,2
    • After gently prying the screen from the frame, carefully thread the tab through the bracket to remove the screen from the phone.
结论
3等其他人完成本指南。
2指南评论
Works great, thank you very much. I changed the microphone with this instruction.
Kai Didschuneit - 回复
Hi there!
The screen replacement works great with this howto.
But - sadly - my phone is now experiencing a huge battery drain. When fully charged it's dead after almost 6 ours. Also the fingerprint-reader is just working when the screen is on.
Does anyone has an idea howto solve this issues?
Thanks in advance!
flux - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 95
总计 9,991
