跳转到主内容
OnePlus 6 Front Facing Camera Replacement
你所需要的
  1. OnePlus 6 Front Facing Camera Replacement, Front Facing Camera: 步骤 1 中的图像 1,2 OnePlus 6 Front Facing Camera Replacement, Front Facing Camera: 步骤 1 中的图像 2,2
    • Use a heat gun to gently heat the back edges of the phone to loosen the adhesive.
    • Use a plastic opening tool to pry the back cover up.
    • Start from one of the left corners and work your way around the phone using the plastic opening tool.
    • Carefully lift the back cover off.
    • Be careful not to damage or unseat the camera cable while removing the back cover.
  2. OnePlus 6 Front Facing Camera Replacement: 步骤 2 中的图像 1,2 OnePlus 6 Front Facing Camera Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to disconnect the red pull-away tab up from the motherboard.
    • Detach the orange camera ribbon cable, below the red tab, using the tweezers.
    • Grip the green tab and lift the battery up and out of the chassis.
  3. OnePlus 6 Front Facing Camera Replacement: 步骤 3 中的图像 1,2 OnePlus 6 Front Facing Camera Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the ten screws from the motherboard harness.
    • Pull the motherboard harness up using the tweezers
  4. OnePlus 6 Front Facing Camera Replacement: 步骤 4 中的图像 1,2 OnePlus 6 Front Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Use the pointed tip of a spudger to lift the front-facing camera's pin connection, gently prying on the plug vertically until it completely releases.
    • Lift the front-facing camera up and out using tweezers.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 24
总计 566
