跳转到主内容
OnePlus 5 Speaker Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. OnePlus 5 Speaker Replacement, Back Panel Replacement: 步骤 1 中的图像 1,1
    • Always make sure to turn off the phone before attempting to replace a part.
    • Power off the phone by holding down the rectangular power button on right side and pressing the red button that says "Power off."
  2. OnePlus 5 Speaker Replacement: 步骤 2 中的图像 1,2 OnePlus 5 Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the two 1mm Torx #2 screws at the bottom of the phone by rotating the screwdriver counter-clockwise.
  3. OnePlus 5 Speaker Replacement: 步骤 3 中的图像 1,3 OnePlus 5 Speaker Replacement: 步骤 3 中的图像 2,3 OnePlus 5 Speaker Replacement: 步骤 3 中的图像 3,3
    • Locate the sim card on the right side of the phone.
    • Insert the SIM ejector screwdriver bit into the hole left of the sim card holder by applying pressure.
    • It is also okay to use the SIM card eject tool for this step.
    • Remove the sim card holder by pulling it out with your fingers.
  4. OnePlus 5 Speaker Replacement: 步骤 4 中的图像 1,3 OnePlus 5 Speaker Replacement: 步骤 4 中的图像 2,3 OnePlus 5 Speaker Replacement: 步骤 4 中的图像 3,3
    • Insert the plastic iFixit opening tool between the the plastic rim of the screen and the metal edge of the phone.
    • Place a suction cup on the screen to gain more leverage when separating the screen from the back plate.
    • Moving right to left around the phone, carefully pry the screen away from the back plate by wiggling the iFixit opening tool and pulling the suction cup in the opposite direction.
    • When reassembling, apply pressure to the edges of the screen and back plate together until they pop back into place.
  5. OnePlus 5 Speaker Replacement: 步骤 5 中的图像 1,3 OnePlus 5 Speaker Replacement: 步骤 5 中的图像 2,3 OnePlus 5 Speaker Replacement: 步骤 5 中的图像 3,3
    • Locate the metal connector cap on the upper half of the device directly above the battery.
    • Remove the 1mm Phillips #0 screw from the metal connector cap by rotating the screwdriver counter-clockwise.
  6. OnePlus 5 Speaker Replacement: 步骤 6 中的图像 1,2 OnePlus 5 Speaker Replacement: 步骤 6 中的图像 2,2
    • Carefully pop out the metal connector cap with the nylon spudger and remove it by pulling up.
  7. OnePlus 5 Speaker Replacement: 步骤 7 中的图像 1,3 OnePlus 5 Speaker Replacement: 步骤 7 中的图像 2,3 OnePlus 5 Speaker Replacement: 步骤 7 中的图像 3,3
    • Locate the two connectors directly above the battery on the left side of the device.
    • Remove the battery connector cable located to the right of the charging port connector cable using a nylon spudger by prying underneath it and popping it up.
    • Remove the charging port connector cable to the left of the battery cable using a nylon spudger by prying underneath it and popping it up.
  8. OnePlus 5 Speaker Replacement, Loudspeaker: 步骤 8 中的图像 1,3 OnePlus 5 Speaker Replacement, Loudspeaker: 步骤 8 中的图像 2,3 OnePlus 5 Speaker Replacement, Loudspeaker: 步骤 8 中的图像 3,3
    • Remove the six 1mm Phillips #0 screws by rotating the screwdriver counter-clockwise.
  9. OnePlus 5 Speaker Replacement: 步骤 9 中的图像 1,3 OnePlus 5 Speaker Replacement: 步骤 9 中的图像 2,3 OnePlus 5 Speaker Replacement: 步骤 9 中的图像 3,3
    • Remove the loudspeaker by gently pushing the spudger underneath it and prying it out.
结论
另外一个人完成了本指南。
Jose Velazquez
于01/24/18注册
866 声望
创作了4篇指南
团队
Cal Poly, Team S19-G1, Livingston Winter 2018 Cal Poly, Team S19-G1, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S19G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 502
