本指南有最近更改,您可查看未经巡查的最新版本。
简介
这个视频展示了如何修复/更换一加3损坏的LCD屏幕。视频中的手机型号为 A3000。在购买替换部件前,请检查你的手机型号。
我们可以修复以下情况的一加3手机:
屏幕破损、破裂或者破碎;
触摸屏幕不能正常工作;
一加3 LCD屏幕为黑色或无法正常响应;
有颜色的像素点或者线条出现在LCD屏幕上;
同一区域的屏幕上带有有黄色、橙色或黑色的像素点;
在一些区域上有类似与彩虹的条纹或者坏点;
触摸屏幕由于不够敏感导致无法解锁手机。
注意:分离一加三的屏幕与后壳是非常困难的。请务必小心操作。
你所需要的
视频介绍
即将完成!
若要重新组装你的设备,按照以下步骤逆序操作。
结论
61等其他人完成本指南。
由衷感谢以下译者:
en zh
0%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
47条评论
Yeah I've done one of these and am literally about to do the 2nd one. Easy as you like :D
Be sure to purchase the LCD with frame as it's much quicker.
drunkenmenace - 回复
Hi,
May I kindly ask, both oneplus 3 and oneplus 3T are the same screen? I'm about to buy a screen with frame and digitizer, and all sellers name their products "oneplus 3/3T LCD screen".
Noémi Dupertuis -
It is sure that Oneplus 3 lcd screen is compatible with Oneplus 3T.
Witrigs -
if the touch still works and it is only the screen to be cracked is there another procedure to follow? Do I need to replace the whole LCD?
Paolo Di Lorenzo - 回复
Yes, because it is really difficult to replace front glass screen only, I prefer you take the whole screen with lcd + front glass+ middle frame.
Witrigs -
I have bought the LCD with Frame assembly ....how do I install the two capacitive buttons from the original damaged phone into it?
carlos - 回复
I did this repair on my phone, but is cracked the screen on the last step... first pop in the top of the phone and than the bottom into the aluminum back!!! And when doing the teardown remove the sim tray first!
Marcell Harmaci - 回复
I made this mistake as well, everything else worked fine though.
Gabriel LaMore -
Be careful during this replacement, because it’s easy to break the earpiece speaker when moving it from the broken screen to the new piece.
Benjamin Hollway - 回复
I second this! It’s so easy to break the earpiece speaker because the it’s made of two pieces that easily separate when, say, your tweezer only picks up the top portion and the bottom held on to the adhesive.
Franklin Ramos -
the touch still works and it is only the LCD cracked is there another procedure to follow? Do I need to replace the whole LCD? And Rainbow pattern or color-blocks shows on some areas of LCD screen..
Airyn Ayryn - 回复
So, I have done it and everything seemed to be fine until I switched off the screen. Although the hardware buttons work, the screen is totally unresponsive. I men the screen works during start up and the entire phone works fine, but when the screen goes black it won't respond.
The only thing I did wrong: I put in the cable that was labeled “sub” and “main” in the wrong way. Could that be the problem? Anyone an idea what I can do?
lordchristoph - 回复
Same here. In my case I had to switch off all gestures and then the replacement screen worked normally. Works OK with my original screen though. Not sure why is this happening, maybe because of low quality ebay crap. But the seller agreed with the return and refund.
lubos -
So what, I need to buy a new battery as well, just to change the screen? I'm so poor
Tara Satana - 回复
Hi Tara,
Unfortunately, with how the OnePlus 3 is designed, you should change the battery also. The lithium-ion battery is easily damaged from any bending occurred when it’s pried out. Replacing it will prevent a lot of future problems.
Arthur Shi -
Will not using adhesive when putting in a new battery be a problem. There is adhesive on my new assembly but I’d like to be able to easely replace my battery in the future. There is adhesive on the new frame with a protective layer you are supposed to peel off, is it ok if you leave that there? Won’t this cause thermal problems? Also, what is the point of removing the battery from the original phone. If you need to get a new battery anyway this shouldn’t be needed right? I mean, isn’t it a little bit stupid to bend a battery if you don’t need to, it is always nice to try to prevent battery fires wherever possible right?
TT-392 - 回复
Hi TT-392,
You are right in that you do not need to remove the battery from the original phone. Removing the battery makes removing the flex cable near the top of the battery easier, but it can be done with the battery in place.
The battery should be held down by at least some adhesive in the phone. The plastic will not cause overheating issues, but you do not want the battery to move in the phone. You can choose to expose some of the battery adhesive so that it will be an easier task to replace it in the future.
Arthur Shi -
So I managed to replace my screen and came across a few things that might help others. I wasn’t able to open the screen from the bottom so I tried the side. In the process of doing this I pulled the screen from the display and broke parts of it. This wasn’t a problem because I was replacing the display+frame. After a few times of opening and closing the phone I have realized that it is a lot easyer to open the phone by pushing the screen out from inside of the sim slot. This could probably damage the sim slot but that is a lot less likely than breaking the screen, at least if you are unexperienced. A friend of mine did damage the back cover by doing this with a metal screwdriver so I would advise a plastic spudger. Also, my buttons ended up acting funny because I replaced the tape with electrical tape, It worked fine after I salvaged some of the old tape. Maybe something other than electrical tape is better.
TT-392 - 回复
I achieved to replace my OnePlus 3 Screen thanks to this tutorial. Thanks !
Côme M - 回复
my glass is a little cracked but display touch is half working and half black. can it be fixed?
sartaj jr - 回复
Hi Sartaj,
If you replace the screen and digitizer, that should solve the problem.
Arthur Shi -
Failed…
https://photos.app.goo.gl/MqgSSxyXXorAAK...
Lucas Hüttenrauch - 回复
Yes, unfortunately you cannot just remove the screen by itself for the OnePlus 3. You have to disconnect things from the back before attempting that. It looks like the capacitative button connector wasn’t disconnected (step 17), and tore. However, if your replacement part came with the capacitative button connector, you’re fine!
This guide is made for screen and frame replacements. It should not be used for screen-only replacement. I will edit the introduction to emphasize that.
Arthur Shi -
This guide worked well for my OnePlus3T. I even used a OnePlus3 screen (or possible a generic) instead of a 3T screen (You can tell because the top corners are rounded and not square. There were only two issues during the process, the first being that when reinstalling the fingerprint sensor I had to put multiple layers of tape between it and the cover for the sensor to be flush with the new screen, and the second being that when reinstalling the motherboard I bent in the clip (which is located at the top of the frame) because I wasn’t sure where it was/how it worked. I’d recommend highlighting the clip in the guide. Otherwise fairly pain free, took a while but nothing was crazy fragile or difficult.
Mathboy 19 - 回复
I’m glad it worked out for you! Thanks for the suggestions—I’ll edit the steps to incorporate your suggestions.
Arthur Shi -
I dropped my phone - nothing is cracked or torn from the outside, but the display slowly progressed to be blue. Touch is still working, but sort of the “blue liquid” has slowly progressed from a few drops to now a lake.
I am confused by some comments, so I hope someone can help me with my questions:
1. For this issue, do I need to change the whole display + frame?
2. Do I need to exchange the battery for this issue? I read it is easier in some cases, but not sure about this case?
The costs are a big issue for me (honestly a little shocked that only the screen is already 120€ here? I have access to all the ifixit tools and that is more than my phone had cost and my budget is 50€. Wondering if better to be without a phone for a few month and buy another second hand A3003 instead?
nerdia - 回复
Hi nerdia,
You don’t need to change the frame. You can choose to change the display itself, but the process is even more involved than this, and adds the risk of damaging the capacitative sensors next to the fingerprint sensor.
We highly recommend you to replace the battery when replacing the screen. You have to take the battery out regardless whether you replace the frame or not, and there is considerable chance the battery is damaged in the process.
As for the decision, that is up to you! The repair is pretty involved, and the OLED panel drives the part price up. This is also a great hands-on learning experience.
Arthur Shi -
Did a screen/digitaliser + battery replacement on my OnePlus 3T. At step 33, Salmontuna makes an absolutely vital point to be aware of. In my OnePlus 3T, this contact pad was adhered to the chasis. I tried loosening the glue with a hair dryer, but the part was so fragile that it simply snapped off. I had to replace the part, which can be found for about £1-2 on eBay. Was a bloody difficult repair, but glad I’ve done it.
Casey - 回复
First time I’ve done anything like this, good tutorial and detailed pictures. Minor point but if you review or update the tutorial, might be an idea to keep the orientation of the phone the same, or a photo at the start of the step to confirm the orientation!
Thanks again!
Brian Clelland - 回复
Thanks for the suggestion! I’ll keep that in mind for future guides.
Arthur Shi -
Is there a guide to replace the screen only? I cannot find it.
Varun Govind - 回复
I have replaced the LCD screen (screen & touch screen / digitizer) and the screen turns on but the touch feature does not work. Where would you recommend I start to troubleshooting?
Michael Stewart - 回复
Hi Michael,
I would suggest checking to see if the display connector has any debris, and to re-seat the connector.
Arthur Shi -
I need some help here
not sure if people still use this forum but i torn down my oneplus 3t and now i’m trying to reassemble it. but i found something very weird. I didn’t find any display cable ??? And when i look closely it’s actually under the case (between screen itself and the screen metal frame). I don’t know how to post pictures here but it’s really confusing me . I could have made a mistake somewhere but i neve opened that part of the phone and i have no idea how the phone was working fine without it
Emir A - 回复
Here is a picture link for my last comment. Bare in mind that i never touched that part of the phone and that the screen was working fine.
https://drive.google.com/file/d/1agEloGa...
i really don’t understand
Emir A - 回复
Hi Emir,
It looks like the cable connector was pushed down and got stuck between the display and the frame. Use a spudger or tweezers to carefully fish the connector out of its recess. It should look something like this. Note that this guide is for the OnePlus 3, which has some minor differences compared to the 3T.
Arthur Shi -
Can you guys give me any suggestion where to buy a screen replacement?
I’m suspicious of the cheap ones from china on ebay which cost around 30$.
Katzz - 回复
I went for such a cheap OLED screen. Had no time to replace it yet but it is more or less an experiment. It is economically not viable to buy a 150 dollar screen to do the replacement in my opinion. The phone is over 4 years old and for 200 dollars a more powerful phone can be bought based on the specs. YMMV
Marc Fellman -
Very good guide, perfectly. My Oneplus 3T now is like a new one.
Michele Bonanomi - 回复
I followed the instructions and everything works fine except for the last step - I can’t get the new screen and frame to go back into the case.
Has anyone else experienced this?
I’ve tried differing angles, light and harder pressure, but the screen seems to be standing proud of the rear case. And the power button and sim slot not aligning.
Any advice?
Thanks,
Steve Williams
Steve Williams - 回复
Hi
I faced similar issue because the replacement batterie I bought was not exactly the same size as original one. Since it was a bit larger, it was up on one side.
Measure the size of original and spare battery if you can
yohann bouvier -
Thanks, I’ll check that, though it was supposed to be a genuine oneplus replacement battery - but who knows with Ebay!
I’ve realised the replacement screen I fitted is thicker than the original so this may be a factor too.. Unfortunately I suspect the new screen I bought was not a genuine part!
Steve Williams -
if it’s from Ebay, I don’t really think it’s a genuine battery. I don’t know policy in each country but at least in France, OnePlus doesn’t sell the battery. You have to go through their support service.
yohann bouvier - 回复
Step 36 just destroyed my speaker. The speaker split in two and the copper coils broke off from the magnet.
Karl Morrison - 回复
Summer of 2023 and our 3t's are still going strong. My son broke his screen and this guide was exactly what I needed.
Thanks so much.
Daddadook - 回复
Replacement of a broken display worked very well.
Some minor details were different with my ONEPLUS A3010_28_191104 model.
The frame grounding clips near the switches (step 38) seem to have been omitted in the display of my phone.
The two screws to open the case were P2, not T2 — not a problem with the iFixit bit set, and maybe the repair shop that fixed the phone before replaced the screws.
The repair shop that did the last fix may have made my job easier, by omitting quite a bit of adhesive (and a screw or two).
Nasty surprise: When reassembling, the phone informed me that the replacement battery from iFixit isn't compatible.
Fortunately, the old battery was still in good shape, so I kept using it.
Thanks for a very helpful repair manual!
tatzelbrumm - 回复
The display from my OnePlus 3 loosened from the frame. Which glue do I use to tighten them together again?
Phil Flowerpot - 回复
