跳转到主内容
OnePlus 2 Motherboard Replacement
你所需要的
  1. OnePlus 2 Motherboard Replacement, SIM Card: 步骤 1 中的图像 1,3 OnePlus 2 Motherboard Replacement, SIM Card: 步骤 1 中的图像 2,3 OnePlus 2 Motherboard Replacement, SIM Card: 步骤 1 中的图像 3,3
    • Make sure that your phone is turned off before proceeding
    • Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
  2. OnePlus 2 Motherboard Replacement: 步骤 2 中的图像 1,3 OnePlus 2 Motherboard Replacement: 步骤 2 中的图像 2,3 OnePlus 2 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Locate the SIM card tray on the back of the phone
    • Use your thumb to gently slide out the tray
  3. OnePlus 2 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the SIM card tray
  4. OnePlus 2 Motherboard Replacement, Battery: 步骤 4 中的图像 1,3 OnePlus 2 Motherboard Replacement, Battery: 步骤 4 中的图像 2,3 OnePlus 2 Motherboard Replacement, Battery: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Find and carefully remove all 6 rubber screw covers with the tweezers.
    • Unscrew all 18 screws from the mid frame.
  5. OnePlus 2 Motherboard Replacement: 步骤 5 中的图像 1,3 OnePlus 2 Motherboard Replacement: 步骤 5 中的图像 2,3 OnePlus 2 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Carefully pry up the mid frame from the back of the phone with the plastic opening tools.
    • Slowly work your way around the phone releasing all the clips that hold the frame in place.
  6. OnePlus 2 Motherboard Replacement: 步骤 6 中的图像 1,3 OnePlus 2 Motherboard Replacement: 步骤 6 中的图像 2,3 OnePlus 2 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Using the spudger tool, pry the battery up from the adhesive.
    • Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
  7. OnePlus 2 Motherboard Replacement, Front and Rear Camera: 步骤 7 中的图像 1,3 OnePlus 2 Motherboard Replacement, Front and Rear Camera: 步骤 7 中的图像 2,3 OnePlus 2 Motherboard Replacement, Front and Rear Camera: 步骤 7 中的图像 3,3
    • Use the spudger tool to pry off the connections at the bottom-right of the front-facing camera.
    • Be sure to disconnect both connections before attempting to lift off the wiring.
  8. OnePlus 2 Motherboard Replacement: 步骤 8 中的图像 1,2 OnePlus 2 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Use the spudger tool to pry off the connection on the left of the front facing camera.
  9. OnePlus 2 Motherboard Replacement: 步骤 9 中的图像 1,2 OnePlus 2 Motherboard Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Use the tweezers to lift up the camera from its groove.
    • The camera has a long, flat portion at the bottom, so be sure to slide the camera up while lifting it up.
  10. OnePlus 2 Motherboard Replacement: 步骤 10 中的图像 1,3 OnePlus 2 Motherboard Replacement: 步骤 10 中的图像 2,3 OnePlus 2 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Use a spudger to pry off the connection below the front-facing camera.
    • Using the tweezers, carefully remove the camera from its groove.
  11. OnePlus 2 Motherboard Replacement, Charging Port: 步骤 11 中的图像 1,2 OnePlus 2 Motherboard Replacement, Charging Port: 步骤 11 中的图像 2,2
    • Use the spudger tool to pry up the top connection of the charging port.
    • Follow the cable with the spudger and slowly pry it up from the adhesive holding it down.
    • Stop at the next connection.
  12. OnePlus 2 Motherboard Replacement: 步骤 12 中的图像 1,3 OnePlus 2 Motherboard Replacement: 步骤 12 中的图像 2,3 OnePlus 2 Motherboard Replacement: 步骤 12 中的图像 3,3
    • Again, using the spudger tool, pry up the final 4 connections on the charging port
    • Again, just like before, slowly follow the cable with the spudger tool lifting it up from the adhesive backing.
  13. OnePlus 2 Motherboard Replacement: 步骤 13 中的图像 1,3 OnePlus 2 Motherboard Replacement: 步骤 13 中的图像 2,3 OnePlus 2 Motherboard Replacement: 步骤 13 中的图像 3,3
    • Using the spudger tool on the bottom of the phone, push the charging part inward.
    • Once the charging port is free from the frame, use your fingers to remove the charging port the rest of the way.
  14. OnePlus 2 Motherboard Replacement, Motherboard: 步骤 14 中的图像 1,2 OnePlus 2 Motherboard Replacement, Motherboard: 步骤 14 中的图像 2,2
    • Use the spudger tool to pry off the long wire connecting the motherboard (top) and the daughter-board (bottom).
    • Try to use the spudger to pry off as much of the wire as possible before attempting to remove it.
  15. OnePlus 2 Motherboard Replacement: 步骤 15 中的图像 1,3 OnePlus 2 Motherboard Replacement: 步骤 15 中的图像 2,3 OnePlus 2 Motherboard Replacement: 步骤 15 中的图像 3,3
    • Use the spudger tool to pry off the 2 connections at the bottom-left of the motherboard.
  16. OnePlus 2 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Use the screwdriver to unscrew the screw fastened at the bottom right of the motherboard.
  17. OnePlus 2 Motherboard Replacement: 步骤 17 中的图像 1,2 OnePlus 2 Motherboard Replacement: 步骤 17 中的图像 2,2
    • Use the spudger tool to pry up the connection at the top of the motherboard.
  18. OnePlus 2 Motherboard Replacement: 步骤 18 中的图像 1,3 OnePlus 2 Motherboard Replacement: 步骤 18 中的图像 2,3 OnePlus 2 Motherboard Replacement: 步骤 18 中的图像 3,3
    • Insert the spudger tool underneath the bottom right corner of the motherboard.
    • Gently work your way around the underside of the board, making sure that it is completely detached before attempting to remove it.
结论
13等其他人完成本指南。
Kayla Williams
于10/01/15注册
1,544 声望
创作了6篇指南
团队
Cal Poly, Team 4-5, Maness Fall 2015 Cal Poly, Team 4-5, Maness Fall 2015 的会员
CPSU-MANESS-F15S4G5
4 名成员
创作了19篇指南
3指南评论
Perfect. How can change de microphone and audio plug?
something?
Adolfo Mendoza Gutierrez - 回复
where can i find the replace of the motherboard?
Georgina Patron - 回复
hi,
where the wifi antena location?
Nimrod Cohen - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 33
总计 12,878
